A thread was started on the Yahoo board by a guy that wanted his spare wheel to match the aluminum (American Racing) wheels on his Chevy based Roadtrek. He bought another of the AR wheels, and then found it did not fit properly on the tire carrier because the offset was different. This has started a very interesting discussion, of which I have been very interested. It, at first, seemed to be no big deal, but when I looked into it further, I developed a different feeling about it.
It appears that Chevy light truck front suspensions are not like the old rear drive, twin a-arm stuff we are used to, which used zero offset wheels. The OEM Express wheels have 28mm of positive offset, which moves the wheel center in over the wheel bearings better, and also reduces the scrub radius a lot. The AR wheels that Roadtrek uses have a minus 6mm offset, so the wheel centerline is moved out 34mm, or nearly 1 3/8". I did some measuring and calcs, and it looks like it over doubles the load on wheel bearings, and reduces the spring, sway bar, and shock rates by over 10%. Perhaps, with the OEM wheels, the van wouldn't need the 5000# Tuff-truck springs, and could go with something softer. i would guess the Roadtreks with aluminum wheels sit lower in the front than the ones with OEM wheels.
We have the aluminum wheels, and have already had a wheel bearing failure at 12K miles, so it interests me a bunch. My current feeling is that we will change to the OEM wheels before we start traveling for real (Alaska and such).
I will be very interested to see how the wheel change will affect the handling and ride, since we have the 5000# springs, bags, Bilsteins, and the rear sway bar.
Anyone want to trade wheels, or buy our hardly used AR wheels and tires (13K)?
