10-25-2021, 04:48 AM
Roadtrek side window replacement?
Have a 2011 Roadtrek 210P with a shattered top half of the rear side window. Can anyone tell me where I might find replacement glass?
01-23-2024, 08:41 PM
We also have a 2011 Roadtrek that needs a side window repair. Has anyone found a source for this? Thanks!
01-23-2024, 10:31 PM
Curious...
Do either of you know; When, or How, these windows shattered? - Internal - Self-induced, eg. something from inside the van
- External - Rock flying, or other object while driving
- External - Tree limb, storm damage, etc..
- External - Vandalism
- External - Temperature differential
- Other
Just looking for an "ounce of prevention."
CHeers - Jim
01-24-2024, 02:09 PM
In our case we think it was a stray golf ball! Not sure if there is anything to do to prevent that.
01-26-2024, 06:45 AM
This is what I think I know.
The original CR Lawrence windows, due to proprietary agreement, can only be bought through Roadtrek. Roadtrek isn’t selling.
Do a search of van windows. CR Lawrence is still in business and has a list of windows it sells. Other companies sell comparable windows.
Get your cutout dimensions and try to match them up with a standard product from any of the van window companies. Hope you find one. I haven’t had to go through the exercise yet. It is still in my furture.
01-26-2024, 12:54 PM
Thanks! That is what we have been doing. So far we haven’t had much luck. The windows available don’t fit the opening - either too small or too large. We have been asked if we would consider cutting a larger hole. We really don’t want to do that. We’ll keep looking. Thanks again for your suggestion.
01-26-2024, 04:28 PM
Try a Pleasure Way window. Hopefully you have a dealer nearby.
The minor problem is they sell parts through a VIN number. You don’t have a Pleasureway VIN number so their system collapses. If you can find a Pleasureway with a similar sized window get the VIN number and with the dealer’s help order a replacement.
My memory says the window sizes are very close. I was headed that way years ago but didn’t complete the quest.
01-26-2024, 04:56 PM
Great idea! Thanks - we will try that!
01-26-2024, 04:59 PM
I remember it being a perfect match with the Chevy Pleasureways.
You won’t be listed as the owner of that VIN number so their system will have a hissy fit but if the dealer will work with you, you can make it happen.
01-30-2024, 10:52 AM
Window was replaced with plastic before I bought. I have been looking for glass for long time and have had no success. Replacement is a cheap plexiglass and looks bad so replacing is in the bucket list. 02 Roadtrek 200
01-30-2024, 01:54 PM
I am working a few leads. I’ll post if I’m successful in getting it replaced.
01-30-2024, 02:12 PM
Just curious, with the plastic replacement were you able to open and close the window? I would think that would be a decent fix. Maybe a better plastic replacement could work for you? Just a thought.
01-30-2024, 02:17 PM
Plexiglass is a comon term (like Xerox/Kleenex). If you can't find the glass replacement, Lexan (another common term for a more durable polycarbonate) is available with a UV coating to enhance weathering. Also available smoked, it is "virtually" indestructable" - so less worry for that errant golf ball!
There are shops online to custom cut, or perhaps a "traditional" sign shop could accomodate.
Cheers - Jim
01-30-2024, 02:34 PM
I cut smoked plexiglass for my 05/04 Roadtrek 190P. Worked well.
01-31-2024, 12:26 AM
There appears to be more to it than going to Home Depot, buying a piece of plexi and cutting it. I have not investigated but need a UV protected plastic or you get what I have, kinda junky looking.
01-31-2024, 01:02 AM
This is what I purchased along with a scoring tool:
01-31-2024, 02:47 PM
I have seen plastic replacements that were indistinguishable from glass until very close examination, and even then it looked good. Probably material like Bud used
02-24-2024, 10:48 PM
A Pleasure way side window on a Ford E-350 Van is 33 1/2 inches wide by 24 inches tall. I don’t have access to my Roadtrek 190P to compare.
Anyone want to measure and compare?
02-26-2024, 07:29 PM
OS dimensions on my 02C190P rear side window is 34" wide x 23 5/8" high
02-26-2024, 08:23 PM
Close enough. Replace a broken Roadtrek window with a pleasure way window.
