I'll have to think of something for the windows. I'm thinking something thicker with magnet strips to hold it on (I'm thinking the back doors).
I have been in contact with the support people at heatline.com. Very helpful if you're interested. They told me that for normal RV pressure piping (PEX or metal) running their Kompensator product along the line's length and wrapping with foam insulation is more than sufficient. The product is self temperature regulating. They did say for the 1 1/2 to 2 inch under floor piping, you have to wrap the Kompensator around the pipes between 2 and 3 feet per foot of pipe depending on how cold it gets. Everything has to be wrapped in pipe insulation to be effective. They also have valve heaters for the gray and black valves. I have only seen Ultraheat.com tank heaters, and they strongly recommend insulating the tanks. I'm thinking to spray them with closed cell foam. I have 2" of it on my basement walls - you could heat the room with a candle. I'll keep you posted on my progress - of course after I receive the van.
