Old 06-11-2020, 10:27 PM   #1
eric1514's Avatar
Default Battery Isolator Question
If you're plugged into shore power, should the battery isolator relay be hot to the touch. I would think it should be cold since its job is to prevent current from passing through it. I also get the same voltage reading on either side of it when I measure at the large terminals to a ground.
TIA
"Il Travato Rosso"
2015 Travato 59g
Old 06-12-2020, 12:22 AM   #2
TIA
What is the make and model of your isolator?
Old 06-12-2020, 12:25 AM   #3
If it’s hot it’s closed and conducting electricity to or from the batteries. That the voltage is the same on either side is further proof it’s closed and conducting electricity.
Generally you want it closed when parked and using it.
Open when stored.
If it’s too hot to touch you have a problem, bad or overloaded.
mikeehlert is offline   Reply With Quote
Old 06-12-2020, 12:46 AM   #4
eric1514's Avatar
Open when stored.
I thought that the only time it would be allowing current through itself would be when the alternator is running so that the alternator would charge the chassis battery and the coach batteries. I thought that it would prevent shore power or generator power through it to the chassis battery. That's why we install Trik-L-Starts.
"Il Travato Rosso"
2015 Travato 59g
Old 06-12-2020, 12:50 AM   #5
eric1514's Avatar
I'm not sure. I can't get my head in there to see. Here's a pic. It's the top silver canister.
I was going to replace it with a Cole Hersee 24213.
"Il Travato Rosso"
2015 Travato 59g
Old 06-12-2020, 01:24 AM   #6
Is that a solenid switch?
could be hanging up
smack it with the heel of your palm
If this was every operated with low voltage the internal contact disk could be carboned up and need cleaning
mike
Old 06-12-2020, 01:29 AM   #7
I think what you have is a bi-directional separator setup rather than a uni-directional isolator. When the alternator is running , the relay (silver canister) is activated and is charging both engine and coach batteries. During shorepower operation, (unlike a basic isolator), the relay is also active to permit the battery charger to address both batteries.
So seeing an active relay during shorepower operation is to be expected and the fact that battery voltage is the same on both batteries verifies this.
These relays do run fairly hot and it isn't helped when they don't have a heat sink like a fender well. They eventually jam in either the open or closed condition. IMO, the arrangement is working as it should but if you intend to replace the relay, a Cole Hersee product is the only way to go.
BTW, what battery terminal voltage are you seeing during shorepower?
Old 06-12-2020, 01:32 AM   #8
eric1514's Avatar
could be hanging up
mike
I’ll try hitting it tomorrow. I’m sure it was operated with low voltage. The previous owners knew less about batteries and maintenance than I do. Even if smacking it works, I’m probably going to have to replace it as it doesn’t look like it comes apart.
I just wanted confirmation that when parked and plugged in to my house 1) It should not be hot and 2) I should read different voltages at each end.
Old 06-12-2020, 01:37 AM   #9
eric1514's Avatar
Thanks, that's a different set-up than I'm used to. The lower canister clicks when I push the "boost" button in the cab.
As far as voltages, the coach has a Progressive Dynamics converter so the voltages vary with time but when I checked it last, I was around 13.47 on both sides.
"Il Travato Rosso"
2015 Travato 59g
Old 06-12-2020, 01:38 AM   #10
could be hanging up
mike
These type of solenoids are sealed units and there is no easy way to access the power contacts.
Old 06-12-2020, 01:50 AM   #11
I misread your initial post. Isolator relay Should be cold and voltage across it when engine is off.
Stuck or miswired.?
Old 06-12-2020, 01:52 AM   #12
Right. Not hot and voltage across it because it should be open.
Old 06-12-2020, 01:52 AM   #13
eric1514's Avatar
That’s what I’m thinking. I’ll just replace it for piece of mind. Thanks for your help.
Old 06-12-2020, 01:57 AM   #14
eric1514's Avatar
Stuck or miswired.?
No problem. I thought it should be cold also but cruising7388 has introduced a new wrinkle. He thinks this might be a bi-directional situation and therefore should be warm/hot when I'm plugged into shore. So it's either that or it's stuck like you suggest.
"Il Travato Rosso"
2015 Travato 59g
Old 06-12-2020, 01:59 AM   #15
Stuck or miswired.?
I don't think anything needs fixing. Seems to me the setrup is working as it's supposed to
Old 06-12-2020, 02:03 AM   #16
eric1514's Avatar
I'm unplugged right now and I'm trying to draw down the house batteries overnight by running the vent fans. Tomorrow I should see different voltages on either side of that solenoid because it should be keeping me from running down the chassis battery. If that's what happens then it's probably as you think. If I still see the same voltage on both sides, then I probably have a faulty solenoid.
That seem like a good test?
"Il Travato Rosso"
2015 Travato 59g
Old 06-12-2020, 03:50 AM   #17
If it is a bi-directional separator setup it typically works this way. When shoreside charging starts the separator will only charge the coach battery until it reads a predetermined voltage (typically 13. at which pointy the separator will combine all batteries for charging. When shoreside power is disconnected, the batteries remain combined until the coach battery voltage drops below 12.8 volts at which point the coach and engine batteries separate.
So, your test should verify if that is the case. It doesn't take much battery load to reduce its surface charge voltage sufficiently to see different terminal voltages on the engine and coach batteries. If the voltages remain identical, that would warrant further testing of the solenoid.
What make and year model is this coach?
Old 06-12-2020, 12:05 PM   #18
The upper canister (no label) is a solenoid. The lower canister (with label) looks like an Intellitec battery disconnect.
Intellitec battery disconnects only use power while switching.
The solenoid uses power to stay closed so they'll get warm. Google search: RV Solenoid Hot - https://www.google.com/search?source...v+solenoid+hot
If the solenoid is functioning automatically as a bi-directional relay when it senses a charging voltage from any source then it is being triggered somehow (my understanding). You might find a "smart" device in the coach such as a Battery Isolator Controller or a Bi-Directional Isolator Relay Delay.
Old 06-12-2020, 01:52 PM   #19
eric1514's Avatar
Thanks folks,
Here's what I found. This morning after being unplugged all night and having 2 vent fans running my batteries where like this.
Chassis-12.84
House-12.35
I plugged in and after a couple of minutes
Chassis-13.56
House-13.56
Unplugged and engine on
Chassis-13.74
House-13.61
The coach is a 2006 Dynamax Isata 250. I know, it's a class C but you guys are smart about this stuff so here we are.
I'm leaning towards a faulty solenoid. I can't think of any test that will confirm that I have a bi-directional system vs. a broken solenoid. The age of the coach and my not being able to find any other "smart" components leads me to believe the solenoid is stuck although it does seem to isolate the batteries when I'm not plugged in.
I guess I'll buy a replacement and swap it out and see. If nothing else, I'll have a replacement.
Thanks,
Eric
"Il Travato Rosso"
2015 Travato 59g
Old 06-12-2020, 02:04 PM   #20
eric1514's Avatar
Quick update. According to someone at Dynamax who haunts the Forest River forum, it is indeed a bi-directional system.
"Il Travato Rosso"
2015 Travato 59g
