08-16-2017, 08:02 PM
RoadTrek Porch Light
Has anyone that has an RT with the useless porch light, removed it or opened it up?
Mine is riveted in place. I want to temporarily move it to see if I can access the wiring for a useful LED light that would be mounted just to the rear of the OE light.
Before doing so, I wanted to see if I could get information that may be helpful.
08-17-2017, 04:17 PM
I plugged in a LED replacement lamp and it has been fine.
08-17-2017, 04:52 PM
I too replaced the bulb with an LED one but I would rather have replaced the whole thing with something better. But I was stymied by the way it was installed - didn't look too easy to remove. Bulb replacement was way easy.
BTW - I was able to replace the lens with an exact replacement I found on Amazon. The great thing about it was that unlike the aged yellowed one I lost the new one was crystal clear,
08-18-2017, 01:40 PM
Replacement lens
Can you send a link or give us more info?
Thanks
Joe
08-18-2017, 02:28 PM
Originally Posted by jmai
Replacement lens
Thanks
Deco 008089-01-700 Porch Light Lens - Clear
08-18-2017, 04:28 PM
Any insight into the manufacturer of the patio light on a 2014 Roadtrek 190 Popular? Looking for possible yellow lense plug and play type replacement. Please, I have all ready called the Mothership and all I got was they are made in China... Thanks
Best. Shorty (aka Shore-T) sends...
Blessed with way more than I deserve.
08-19-2017, 08:44 PM
Originally Posted by Deano
Looks like the identical item! Just hit enter on my terminal. I'M DOING THE HAPPY DANCE NOW!! Thank you Deano. With a 30 day return policy all I can loose is the return shipping and perhaps the bugs if it fits. Thanks again.
Best. Shorty sends...
08-26-2017, 01:16 PM
I satisfied my desire to change out the white bug and insect attracting light cover that came on my Roadtrek 190! I have never liked those white covers given their propensity for attracting annoying flying critters. No need to cut and splice as the replacement cover was the exact form, fit and function, so it was pretty much a plug and play swap. Thanks to Deano who found the cover part on e-bay, I was able to replace in less than 15 minutes. I am now considerably bug free at night and still enjoy an adequate amount of amber lighting thanks to the original LED light array. Without a doubt the white cover provided much more light, but it came with too many unwanted “visitors.”
As a side note, Cindy the proprietor at cmlsurpluscindy (e-bay user ID), is an AWESOME vendor! The original replacement cover arrived with a cracked bottom mounting notch thanks to the USPS and after one email Cindy had a replacement enroute at NO cost to me. That’s service. I think they primarily focus on surplus RV parts, but it certainly is a good asset to check before spending exorbitant costs at brick and mortar RV parts stores. My ultimate goal is to permanently add some amber rope lighting to the under carriage of BIG EDNA II to create that desired outdoor lighting effect. This is a work in progress.
Enjoy the ride! Best. Shorty sends...
08-26-2017, 01:21 PM
+1
Looking nice !
11-16-2017, 09:29 PM
RT Porch Light Can be Removed
Deano -I had an issue with the bulb not making contact in the porch light socket. I have a 2005 190 Versatile with the standard chrome fixture, and it took me about 3 hours to finally get the fixture off. First, I drilled through the two rivots with 1/8 bit. Next, I put painters tape around the fours sides of the fixture to protect from scratches. Next, I used a pen knife , small flat head screw driver, small hammer and just started on one edge and carefully began trying to pry the fixture loose. It was very difficult to pry loose since the entire fixture is embedded in a clay type putty that was holding/sealing the fixture (Of course I didn't know this until I got the thing completely off). Once I was able to work a small screw driver in behind the fixture I then gently worked my way all around to loosen and pry and hammer and loosen and pry and hammer. It was a real pain. I guess RT embeds these things in the putty to prevent leaks, but a rubber gasket seal with screws to hold the fixture in place would have been much easier to work with.
I am thinking of putting a different light up now that I have the old one off. Need to find one that goes up with screws and has a gasket to seal it.
Good luck with your efforts to get yours off.
11-18-2017, 03:38 PM
Hobotech on YouTube replaced his porch light recently on his old 190 Popular
11-19-2017, 12:41 PM
Porch Light
Hello I think our porch lights are different. I replaced my original white lens cover on my 2014 190P with the identical item but with a yellow lens cover instead. Purchased it on line, see post #8 in this thread for vendor info. If interested I can send you mounting and connect jpegs as well. Let me know. See attached jpeg. Best. Shorty sends...
11-19-2017, 01:06 PM
Oval Amber Light Fixture
Internal mount views provided if you decide to go this route. I also painted the top white portion of the mount black to match other items on my vehicle. I checked with the vendor off of the hotlink on post # 8 and there are 8 available for sale. I am not affiliated in any way shape or form with the vendor. Your results may vary. Best. Shorty sends...
04-21-2018, 12:50 AM
Steven, was wondering if you were able to find a suitable replacement for your porch light frame you removed? I have the exact same setup on my 2000 RT versatile 200 and will likely have to remove the entire chrome socket and replace it. Thanks
05-07-2018, 10:52 PM
Well I finally tackled removing the OE porch light to access the wires for a new LED strip light. As stated above, it was a bear to remove. The LED is aimed down 45 degrees aiming the light where I want it. The sellers claim 800 lumens and I will say it is way brighter then the 15 candle power OE useless lamp. I disconnected the OE but replaced it to fill the hole.
https://www.ebay.com/itm/12V-LED-Por...item41e16a77a7
10-27-2020, 03:16 PM
I have a 1995 roadtrek 170P and can't find where the switch is located for this outside porch light. Any ideas
10-27-2020, 10:35 PM
Welcome to the forum 70!
I'm sure some 170 owners will be along with your answer.
10-27-2020, 10:38 PM
I have a 2001 190 Popular. My outside light switch is right next to the water pump switch. It is not marked or labeled.
Joe
10-27-2020, 11:32 PM
On my 05 210 it is next to the door frame a few inches from the top of the door.
