Old 01-20-2021, 02:28 AM   #1
Default Michelin - Agilis CrossClimate LT245/75R16/E + Dill TPMS
Expensive day at Costco today, almost $1000 for new rubber and sensors. I decided to go with Michelin - Agilis CrossClimate LT245/75R16/E. Very quiet on highway, good on corners, van is going very straight with hand off. Took just a few miles to reset new TPMS Dill sensors after they programmed them in with new IDs. Time will tell how good the tires will be in wet or icy conditions.
Old 01-20-2021, 04:03 AM   #2
Many good reviews on those tires!
Old 01-20-2021, 08:36 PM   #3
I put those on my Chev in May ( same size)
in the end my OTD price ( after rebates) at discount tire was $787.01
I'm happy with them- especially in the wet
Old 01-21-2021, 03:10 AM   #4
My tires were $754 installed, and TPMS sensors Dill 433 MHz $176 installed.
Old 01-21-2021, 11:05 PM   #5
Boxster1971's Avatar
I had a set of Michelin Agilis CrossClimate tires installed early last year. They seem to be a good tire but I don’t know why Michelin dropped the warranty.
Old 01-22-2021, 12:26 AM   #6
it appears to be a softer rubber compound- possibly better grip
more wear per mile
mike
Old 01-24-2021, 05:39 PM   #7
I have the Michelin Agilis and have not received any notice of the warranty being dropped. I do know they have discontinued the Michelin Defender and no longer manufacture it. There are still some new /old stock. If you find them it is best to check the manufacture date and warranty.
Dougm38 is offline   Reply With Quote
Old 01-24-2021, 07:07 PM   #8
Warranty wasn’t included with these tires. I asked Costco why, they didn’t know. I based my purchase decision on my past experience with Michelin and multiple positive reviews on Agilis CrossClimate.
Old 01-24-2021, 10:49 PM   #9
warranty dropped altogether???? on your purchase?
my agilis warranty is 50K
the old michelins were 60K
mike
Old 01-24-2021, 10:58 PM   #10
None, Costco Road Hazard warranty only.
Old 01-24-2021, 11:51 PM   #11
mike
They appear to have done away with the Agilis mileage warranty.
But then they talk about pro rated mileage in the warranty, but don't say how they prorate them. All the other LT tires still have a mileage warranty!!
2008 Roadtrek 210V
Formerly:
Toyota Sunrader
Tiffin Allegro
Foretravel U225
Old 01-24-2021, 11:54 PM   #12
when I shopped in May: 50,000 miles
the current warranty is 6 years vs road wear
https://www.michelinman.com/on/deman...ers_Manual.pdf
Old 01-25-2021, 12:07 AM   #13
This is what the site is currently saying. I don't know what the 2011-2017 stuff is about, the page is dated 2021.
https://www.michelinman.com/warranty.html
Old 01-25-2021, 12:08 AM   #14
What warranty did they drop?
Old 01-25-2021, 03:12 AM   #15
They dropped the tread wear mileage warranty.
I went to the Michelin warranty page you linked above and looked at the 2019 warranty flyer listed there:
https://www.michelinman.com/on/deman...uick-Guide.pdf
This flyer is dated 11/17/20 on bottom of last page. There are no AGILIS/CROSSCLIMATE tires listed under the Light Truck, SUV and Crossover Tires tread wear mileage warranty section.
This is consistent with information from NTB, Tire Rack and Costco.
Either way a tread wear warranty doesn't help me because I don't rotate my tires. According to the Michelin Passenger and Light Truck Owners manual tire rotation is required for a tread wear warranty. This is what it says:
"In order to maintain the treadwear warranty on your tires, the tires must be rotated every 6,000 to 8,000 miles (10,000 -12,000 km), or as recommended by the vehicle manufacturer, whichever rotation period is less. Failure to rotate the tires as provided herein voids the treadwear warranty"
Source:
https://www.michelinman.com/on/deman...l-warranty.pdf
Cheers,
- - Mike
Old 01-25-2021, 04:21 AM   #16
Default Costco Refuses
Costco refused to install my Michelins because my 2005 Roadtrek 190 is considered a "Motorhome". Since I'd ordered and paid for them then waited a couple of weeks to get them, I went ahead and had them installed elsewhere. Now Costco won't give any guarantee or even rotate them. I guess they are all lawyered up.
alaskasail is offline   Reply With Quote
Old 01-25-2021, 05:34 AM   #17
Perhaps refusal to install was related to accessibility to jack or hitch lift points or high weight issues. In my case, I had marked jack points and Costco put an experienced person to service my van. They lift my van’s front with 2 jacks and did rear wheels one at the time. My van was almost dry at about 7K lbs.
Old 01-25-2021, 05:43 AM   #18
They said that they didn't have the torque specs for RV wheels.
Old 01-25-2021, 05:46 AM   #19
Wow, I think they didn't want to do it.
Old 01-25-2021, 01:49 PM   #20
I am Costco member but I buy tires at Discount Tire. They will match Costco and service is better. No problem on my Roadtrek 210.
