Old 10-31-2016, 03:23 PM   #1
Default Potty Talk: Rookie Question
Okay, we've had our '04 Roadtrek 190P for a couple of months - have done 5 weekend trips. So far, so good. One puzzler I have yet to figure out is: How come we can flush the toilet without running the water pump? Is there residual pressure in the line?
Old 10-31-2016, 06:00 PM   #2
yes, the pump runs until it reaches a preset pressure- so when parked your lines are pressurized.
if when parked with no use of the water and the pump comes on periodically- that might indicate a leak somewhere.
when parking for any period of time I open the tap to relieve pressure from the lines.
Old 10-31-2016, 06:11 PM   #3
Since the lines are pressurized and the pump is not running unless called for is there any reason not to leave it on all the time while camping?
Old 10-31-2016, 06:50 PM   #4
only if your are afraid of a leak- which could empty your tanks and put water where you don;t want it.
i turn on the pump when using it, then turn it off.
we have had a couple of plumbing fittings shake loose on the road, so why chance it.
had the cold water to the galley sink get loose once Luckily we had a baking tray in the cabinet underneath...and had the drain get loose in the bathroom sink.
I tend to err on the side of caution in most things and my van is a 2006
Old 10-31-2016, 09:47 PM   #5
Yes, there's residual pressure in the lines, but I'm not sure you would get enough water to flush the toilet (though I've never tried it). You probably have an accumulator tank somewhere, like this one:
Shurflo Accumulator Tank - Shurflo 182-200 - Fresh Water Pumps - Camping World
William
2000C200P
WJones is offline   Reply With Quote
Old 10-31-2016, 10:20 PM   #6
You'll get about a half flush is all and you may not have enough to refill the bowl to seal the valve. You need to turn on the pump. It is not that big a deal. No different than the light switch you turn on to use the bathroom.
Old 10-31-2016, 10:26 PM   #7
William may well be right. We have an accumulator, and we can do several short flushes before the pump comes on. Nice for nighttime flushes with a sleeping partner. it also makes the whole system a lot quieter and generally better-behaved. Recommended.
Old 11-01-2016, 12:54 PM   #8
It's not a big deal but in our 190P the switch is on the other side of the privacy door - so a little inconvenient - to date though we've had no issues with running out of water to flush with.
Old 11-01-2016, 12:56 PM   #9
I had thought folks didn't leave the pump on due to not wanting to drain the battery but this appears to not be the issue as it only uses battery when called for - right?
Old 11-01-2016, 01:27 PM   #10
eric1514's Avatar
That is correct.
"Il Travato Rosso"
2015 Travato 59g
Old 11-04-2016, 12:31 PM   #11
One more thing on this subject of using the toilet... I have decided to go ahead and drain my tanks in preparation for the winter. But I still plan on using the RV every weekend possible. Am I correct to think it will be okay to urinate in the toilet followed by a splash of RV antifreeze?
Old 11-04-2016, 12:50 PM   #12
As long as use antifreeze to flush you are fine but maybe more than a splash. Not sure how much you can dilute the antifreeze and still get freeze protection...
Old 11-04-2016, 01:02 PM   #13
What do you mean by "draining the tank"?
Not trying to be picky... draining is not winterizing.
There might be water trapped in the pipes, which can freeze and crack your pipes. You need to flush it with RV antifreeze until you can see pink coming out.
Regarding peeing... what do you plan to do with the urine? Keep it there until next year? You might as well bring a bucket if you are so intended.
Old 11-04-2016, 01:11 PM   #14
With the black tank having just liquids with a majority being antifreeze I guess you could dump it after ever trip or let it sit until it fills up and then dump it. Throw in some tank treatment if you find it smells.
Old 11-04-2016, 01:14 PM   #15
Another option is to use the Walmart version of wag bags placed in the toilet which allows you to avoid flushing altogether and doing all your business not just liquids...
Old 11-04-2016, 01:17 PM   #16
... but where do you dump it?
Most of the dump stations are closed in the north starting late fall.
Old 11-04-2016, 01:27 PM   #17
I am in the process of winterizing... dumped the tanks last weekend and will drain the pipes, blow out any left over water and run antifreeze through the system some time soon.
I reckon with the little amount of liquid that would be going in the tank, it should be fine for a few months. We're only planning on using it for the "middle of the night" runs.
Old 11-04-2016, 01:52 PM   #18
FWIW, the freezing point of urine appears to be approximately 21ºF:
https://icaspar.net/everything-you-n...-freezing-pee/
Old 11-04-2016, 02:08 PM   #19
I've never checked but it is possible that dump stations at RV dealers, truck stops, etc. are open all winter even after campgrounds are closed...
Old 11-04-2016, 04:28 PM   #20
And, of course, there is probably a sewer washout in your yard. Or, a toilet if you have a macerator and a long hose.
Honestly, I have never had a big problem finding wintertime dump stations. Year-round campgrounds, highway rest areas, truck stops...
