Old 10-06-2019, 10:29 PM   #1
Default Tank Liquid Level
Hello - many of the experienced people who post here have helped me in the past. For over three years we worked Saturdays to convert a plain white Sprinter into an RV. Our systems include a Nations secondary alternator, Xantrex inverter/converter/load manager, Blue Seas switch/breaker panels, infloor heat, Rixen diesel heat and hot water, etc. The only system that doesn't work well is the LevelGuard tank "tender." After a fair amount of trouble shooting, I suspect that the sensors provided are not enough to "see" the liquid level of polyethylene/polypropylene tanks that are 5/16" to 3/8" thick - especially near the corners. What system do you use and are you happy with it? Thanks in advance.
tex4judy is offline   Reply With Quote
Old 10-06-2019, 11:10 PM   #2
The Garnet "See Level" family seems to be the best of the non-exotic approaches:
https://www.garnetinstruments.com/rv-shop/products/
In our experience the tank units, which are strips of some kind of capacitive (or some such) sensors that you stick onto the outside of the tanks, are quite reliable. The 7-segment display on ours head unit has always been somewhat flakey, but mostly works as advertised.
Old 10-06-2019, 11:36 PM   #3
Default Thank you
I was looking at those today. Thank you sir.
Old 10-07-2019, 12:08 AM   #4
We also have the SeeLevel and have for quite a while. No issues to this point.
Keep in mind that the unit can't know about odd shaped tank non linear capacity, sitting on a slope, sloshing, etc, so you need to not get overly critical at any given place in time.
We found that making a small chart of actual level vs reading to be very helpful. I just filled the tanks a gallon at a time and noted the reading to make the chart, which is posted next to the display so we know how many gallons to full or empty depending on which tank.
Old 10-07-2019, 12:17 AM   #5
The sensor strips can be cut and daisy-chained, and they don't necessarily have to be installed completely vertically, so a sufficiently anal installer could likely spoof the system to adjust for these things to some extent.
I, myself, am not quite that anal.
Old 10-07-2019, 12:25 AM   #6
Btw, there exists an obscure technical services bulletin that provides important installation information that is not present in the See Level installation installation book:
https://www.dyersonline.com/download...tfile_id/2591/
Notably, you are supposed to protect the sensor strips by coating them with rubberized automotive undercoating compound.
Old 10-07-2019, 02:52 AM   #7
Default Many thanks
Avanti; you and Booster have been very helpful through this process. I smile to remember that I asked you how the buss bars work. And you turned me on to Rixen - complicated install with the altitude add-on; but it works like a charm. Thanks again guys.
Old 10-13-2019, 06:28 PM   #8
I've upgraded to the seelevel system, and it is a lot more accurate than the standard systems. Do follow their advise and tape the sensors into place until you have everything tested and working properly. I didn't do this and had to replace a couple of the sensors (not cheap) because removing them once stuck down can destroy them.
- Steve
'Blue' 2004 Chevy Roadtrek 190 Popular
rauscs is offline   Reply With Quote
tank liquid level, tank tender
