07-28-2015, 04:00 AM
#361
It is less about 12VDC vs 120VAC and more about traditional RV roof-units vs modern, efficient, quiet split units, with the condenser mounted outside. There are plenty of existence proofs of this technology, and they are used routinely in big rigs. I am quite sure that this is the future of RV AC. I don't know if 12V or 120V will prevail, but that is a minor point.
There is no need to be an apologist for ARV because they haven't tackled this problem yet. They are a tiny organization and they can't fight all battles at once. They or somebody else will soon introduce this technology and everybody else will quickly follow. The current B-van AC solutions are laughable and change is imminent. Personally, I can't wait. I don't really care who goes first.
07-28-2015, 03:47 PM
#362
"...modern, efficient, quiet split units, with the condenser mounted outside."
Can you post a link to this type of unit?
07-28-2015, 03:55 PM
#363
there are many of these both dc and ac. truckers use them mostly-why not google
sportsmobile sells one under DANHARD AC name
07-28-2015, 05:33 PM
#365
Looks like Outside Vans uses a 12 volt A/C from the trucking industry. Will Roadtrek now switch to something like this or will it be the A/C placed under the chassis as hinted by RT Campksunk?
07-28-2015, 05:39 PM
#366
In the Amazon link it says 18 amps of DC? You can use almost that much charging your laptop. I wonder how many BTU continuous it will do.
OOps the 18 amps must be at 48 volts which is needs as a separate 8 battery bank so closer to 900 watts and more realistic, but still pretty low. A little of 1000 watts of solar, so you would need to have another charge method if you were to use the AC much, as the solar wouldn't take care of it by itself.
07-28-2015, 05:59 PM
#367
In the 210P they are testing some kind of 12v split system in lieu of their 10,000 btu CoolKat window unit style AC.
I was surprised to hear this, as that window type unit is pretty low consumption - and there are others of similar size that are alot lower amperage.
I'd like to know what their reasoning is in this application as it's different that replacing a rooftop unit.
07-28-2015, 06:03 PM
#368
Would this kind of split system work on the Zion as well?
07-28-2015, 06:40 PM
#369
limited space under zion as is. if you keep the standard battery and move the tire to the back maybe
07-28-2015, 06:53 PM
#370
Dometic and Coleman both have lines of split systems intended for trucks. A company called "Big Rig Products" in OK City frequently have "lightly used" systems at good prices:
Dometic Truck AC Units
I could easily fit the inside part of such a system into a rear cabinet. Almost certainly MUCH quieter than those... THINGS we all have on our roofs. I am very tempted.
07-28-2015, 08:25 PM
#371
Or just eliminate the spare tire altogether.
07-29-2015, 02:05 AM
#372
I could be confused, but I thought I read over on the Facebook page some talk of RTs with some sort of under the floor AC unit. I think the owner was having problems with it and the discussion got over my head so I didn't finish reading the thread.
2015 Roadtrek 170
2011 LTV Libero
2004 GWV Classic Supreme
01-02-2017, 05:02 PM
#373
Dragging up an old thread. Sorry.
My understanding is these etrek batteries use 60w when they are turned on.
Is this still true?
01-02-2017, 05:31 PM
#374
Is this still true?
NO
The old ones did.
THey have updated the hardware/software.
The draw is much less now.
01-02-2017, 05:40 PM
#375
Do you have numbers? How much less? Thanks
01-02-2017, 05:41 PM
#376
Originally Posted by BBQ
NO
The old ones did.
That's vague. What is the draw now?
01-08-2017, 08:26 PM
#377
somewhere between 0 dots and 1 dots, I suppose...
01-08-2017, 10:22 PM
#378
I remember seeing a quote by Jim H claiming the new draw is "about 35 watts".
Need input from anyone with the newest version.
01-09-2017, 12:26 AM
#379
I don't dislike Jim but many of the thinks he says are incorrect or seemingly fictitious.
'About' could be ?
01-09-2017, 12:27 AM
#380
I have the more recent version but there is no way to measure the draw with the system as provided because the multiple battery management systems makes it impractical to install a shunt driven meter that measures the overall state of charge and operational and parasitic amperage draw.
