Old 09-09-2018, 09:24 PM   #21
Originally Posted by Gary Mn View Post
To our 2008 RS I have added the following major items:
1. Komi adjustable shocks on rear
2. Spring assist kit on rear
3. Coil over springs on front struts
4. Two gallon pressure tank to water system
5. PPI hard wired surge protector
6. Nova Kool compressor refrigerator
7. Removed DVD player and replaced with BluRay player connected to TV only side other speakers never seemed to work right
Gary
2008 RS
Minnesota
Re number 7, it is likely that the "surround/vehicle" switch is miswired, as ours was from the same era. I have read about quite a few others from then that had the same issues. We had a couple of dead speakers because of it. There are a lot of tiny wire connections on that switch, and Roadtrek will not give you the wiring diagram so you can fix it. It took me half a day to figure out what to do.
Old 09-09-2018, 09:46 PM   #22
Booster,
Thanks. Our speakers did work with certain DVDs but we rarely used the front ones and the DVD itself was failing so took the path of least resistance. I could add a device (do not recall what it is called but my son-in-law knows)that would amplify the signal and send to all speakers for about $80 but am satisfied with this for now. The Blu Ray player was pretty inexpensive too and I made wiring to TV simpler compared to what RT had in stalled
Gary Mn is offline   Reply With Quote
Old 09-10-2018, 01:54 PM   #23
DaveBad's Avatar
Default Great West Van Mods
1) Installed a wifi booster
https://www.amazon.com/Alfa-range-re.../dp/B07C8915BV
2) Installed Roadmaster steering stabilizer
3) Installed a 50w Renogy solar panel and controller
4) Installed a new TV up front
5) Installed a LED light fixture with dimmer
https://www.ebay.com/itm/RV-Interior...72.m2749.l2649
Next up USB ports tied into the house batteries.
DaveBad is offline   Reply With Quote
Old 09-10-2018, 06:39 PM   #24
DaveBad #2 link same as #1 link.
Willie_B is offline   Reply With Quote
Old 09-10-2018, 08:47 PM   #25
DaveBad's Avatar
can't seen to Edit the post so here is the correct link:
Thanks
Old 09-22-2018, 01:48 PM   #26
ponti33602's Avatar
Finally installed our new tv bracket so we could rotate the current 24” standard tv in portrait mode. They really have simply installed a 19” so this wouldn’t be necessary.
The mount was from monoprice ($24 delivered). I reused 2 existing holes and plugged the third. This mount feels a pound or two lighter. We watch tv seldom so this gets it out of the aisle for us. IMG_3971.jpg
Regards,
Bob
2017 RT Agile SS
ponti33602 is offline   Reply With Quote
