Old 11-24-2006, 01:37 PM   #1
Default Covers for Class B RV's
I'd like to put all of the sources for covers for camping vans that we can find in this thread.
Here's what I've found so far:
Roadtrkek Boutique
http://www.roadtrekboutique.com/product ... tegoryID=4
Cover Search (I don't know anything about these)
http://www.coversearch.com/rv/classb.htm
Calmark
http://www.calmarkcovers.com/roadtrek.html
Hugger Covers
http://www.huggercovers.com/catalogue/rv.html
Sprinter Accessories
http://www.sprinteraccessories.com/051_van_cover.html#
Adco
http://www.adcoprod.com/sfs_aqua-shed_class_b.htm
If you know of any others add them to this thread. If you had or have a cover let us know if you liked it and was it any good. How long did it last? Was it easy to put on and take off?
Old 12-06-2006, 02:44 AM   #2
Silver Member
Default Class B Van covers
I purchased a cover from the www.roadtrekbotique.com/ and have only had it for just under a year now. It is a bit pricey but it really is very high quality, and fit is excellent. It is designed for two people to install it, and can be done easily with two. I normally end up doing it alone, and it is kind of a pain alone. Once you distinguish which end is which, it goes pretty fast. It is marked, but there is so much material in your grasp, it is a little difficult to get the correct end going on 1st. It will do a great job of protecting the finish though, and it has side door access and rear door access also.
Steve & Chris
2006 Chevy Roadtrek 190 V
FMCA #376666
Barman is offline   Reply With Quote
Old 01-01-2007, 11:50 PM   #3
Default Covers for B's
I bought one for our RT190P thru CalMark and am definitely satisfied. This is my second purchase thru them (had a TT before). It is quality all the way...and I like being able to get in and out of it without having to remove it in total or even partially. Solid Recommendation here, Ron
Ron J. Moore
'15 RT210P
