Old 01-16-2017, 04:41 AM   #1
Default How Much Solar is Enough Solar?
Old 01-16-2017, 04:42 AM   #2
screen shot from...
Old 01-17-2017, 03:13 PM   #3
I have got to go to see that spectacle!
Marley is offline   Reply With Quote
Old 01-17-2017, 03:30 PM   #4
that's a start...
Old 01-17-2017, 10:54 PM   #5
Sticking to Class Bs, this is Solar Womp built by Advanced RV. It has 1150watts.
That is probably the max out number. I believe Mike Wendland and Campskunk have around 900watts in their beta test EcoTreks.
Solar Womp was built for a single purpose of spending a week in the August Nevada desert at Burning Man. It has some other air conditioning innovations and no windows other than the cab area and sliding door. I think the owner has discussed it here in the past.
Old 01-17-2017, 11:14 PM   #6
wincrasher's Avatar
Just to give some perspective on how much that is, I put 1280 watts on my bus - IMG_3607.jpg
2019 Winnebago Travato GL
Old 01-18-2017, 02:10 AM   #7
Wincrasher how are you liking the new bus? Any big trips in it yet? Looking at your photos and other class A's the outside storage and space for system handling is really nice compared to a B.
Old 01-18-2017, 03:06 AM   #8
That certainly doesn't occur very "stealth".
talktodean is offline   Reply With Quote
Old 01-18-2017, 03:33 AM   #9
at least the first guy can ( with some work)...point his solar at the sun.
Old 01-19-2017, 12:34 AM   #10
wincrasher's Avatar
Lovin' it. Getting ready to head out west soon. Been spending the time doing mods on it - has taken alot longer than I thought, but I like how all of them have gone.
My big lithium battery is coming tomorrow, and I'm very excited to get it installed. Then I will be done with all the planned projects.
I might take a long weekend down to the coast. We having unusually warm weather lately, so it might be an enjoyable trip.
Old 06-17-2017, 12:51 AM   #11
Old 06-17-2017, 01:12 PM   #12
The Wynnes are fun to watch and they make great informative videos!
WingedRyno is offline   Reply With Quote
Old 06-17-2017, 02:03 PM   #13
eric1514's Avatar
"In series" doesn't mean "panel 1 is connected to panel 2 and panel 2 is connected to panel 3" and so on.
"Il Travato Rosso"
2015 Travato 59g
Old 06-17-2017, 03:00 PM   #14
Yes... and the voltage increase with each panel.
The benefit is, with higher voltage configuration you get less energy loss over the same distance than with a high amphere configuration,
and you can use thinner wire (less weight).
The downside is, if one panel is shaded, the overall efficiency dramatically decreases.
For Wynne's case, they chose the series configuration because they are in the desert. ie. no shades.
Some people use a combination of series-parallel to optimize the panels for varies shading situation.
Old 06-17-2017, 03:12 PM   #15
eric1514's Avatar
I'm aware of what the terms mean. I'm just saying that if you're going to make a humble-brag video, stick to bragging and don't try to be educational when you're not sure of what you're talikng about.
"Il Travato Rosso"
2015 Travato 59g
Old 06-17-2017, 03:47 PM   #16
I did not watch the video, but that is exactly what "in series" means. If the Wynn's said otherwise or wired in parallel and said it was series, the were incorrect, but the description you say is wrong is correct.
Old 06-17-2017, 03:54 PM   #17
eric1514's Avatar
I can connect panel one to panel two either in series or in parallel.
"Il Travato Rosso"
2015 Travato 59g
Old 06-17-2017, 03:54 PM   #18
So you're now saying they were correct with their educational video when discussing what series meant, and you just said they were wrong because you think they were humble bragging?
I didn't see any bragging in the video but then I just watch their videos for the education so I may have missed it.
Old 06-17-2017, 03:57 PM   #19
Can you connect panel 1 to panel 2, and panel 2 to panel 3 and so in parallel or would that be connected in series?
Old 06-17-2017, 04:02 PM   #20
eric1514's Avatar
You can connect as many panels as you want together in series or in parallel.
