Old 01-10-2021, 06:30 PM   #1
Default LP Gas Line
Want feedback on way to fix or purge air from LP gas line. Hopefully this is something I can do myself? We have a 2017 Era 70A. Stove burners light but don't stay lit but for a second or two. Assume the line has air in it. Owners manual say take propane dealer. I can't believe the Pilot truck stop attendants will know what to do. Thanks for replies...
KYRuss is offline   Reply With Quote
Old 01-10-2021, 07:21 PM   #2
More likely the thermocouple safety shutoff on the stove is bad. Will it stay lit if you hold the valve down in its "start" position?
Old 01-11-2021, 04:07 PM   #3
Pilot Truck Stops are NOT propane dealers! And regretfully, many propane dealers will tell you to take it to a RV repair shop! And many RV repair shops have no clue!
2008 Roadtrek 210V
Formerly:
Toyota Sunrader
Tiffin Allegro
Foretravel U225
Old 01-17-2021, 04:52 PM   #4
When I want to purge air from the propane line, I generally light the stove to get propane to the refrigerator without the Check light activating.
In your case, I would run the furnace. However, I agree it is probably the flame detector that is the problem.
Roadtreker357 is offline   Reply With Quote
Old 01-17-2021, 07:45 PM   #5
I agree with others that probably your "Thermocoupler/Detector" is the culprit. I had a similar problem, and I used an pencil eraser to clean the coupler and all works well since. I think overtime the buildup of "carbon" around the coupler prevents it to send proper signal to the gas valve. Just a suggestion.
habsfan59 is offline   Reply With Quote
Old 01-17-2021, 08:17 PM   #6
Wipe the therocouple, lightly with fine sandpaper...did mine 3 years ago, and no issues since...ex HVAC tech
Thread Tools
Display Modes
