11-18-2016, 01:09 AM
#61
Originally Posted by cruising7388
Maybe more than that? From the recent Roadtek power budget bulletin:
"Inverter - 100 watts (Yes, the inverter uses power. Turn it off when not needed.)"
I have seen that but it does not match the spec for the inverters so where it comes from is a mystery as with many things from Roadtrek...
11-18-2016, 01:18 AM
#62
Maybe they were counting on both being on.
11-18-2016, 10:23 AM
#63
Originally Posted by dknightd
Thanks. I'm thinking maybe the "continental" spare tire mount is not needed.
If so, it would be nice to have easier access to both rear doors.
I have not been able to see one of these vans with the Li batteries and no propane yet.
Not much room.
Regards,
Bob
2017 RT Agile SS
11-18-2016, 10:35 AM
#64
Originally Posted by ponti33602
Not much room.
Those are lithium batteries.
11-18-2016, 11:49 AM
#65
Do you have the 400AH or 800AH ecotrek option, looks like just 400AH (two modules) or are there two more that aren't shown?
11-18-2016, 12:23 PM
#66
We only got the 400. She researched and thought for our needs that was the right amount. We ended up with:
300 Solar (Only got 300 due to keeping height of van down - other posts)
400 Lithium
Diesel Alde (No Propane)
Charcoal (out)/Grey (in)
Volt Start (Under Hood Gen)
I questioned whether we should have gone with 800 but she said "no". We will see. Her logic was we wouldn't be staying anywhere more than 1 day or 2 at the most. Also, she is not a fan of air (keeps our house set to 80-81 degrees) so she believes we are okay....time will tell.
Regards,
Bob
2017 RT Agile SS
11-18-2016, 01:12 PM
#67
That analysis makes sense to me...
#68
Don't side with her.
Regards,
Bob
2017 RT Agile SS
11-18-2016, 01:14 PM
#69
It is too bad that they can't put the lithium batteries inside the van both to preserve the spare tire space but also to keep them warmer for charging in colder weather.
What is inside both of the side ottomans? Is there any storage space there? That would have seemed like a good place for batteries.
Thanks for posting the info and great pics.
11-18-2016, 01:17 PM
#70
Good question and I am not sure.....in Tampa at least I am not concerned about the cold. We just got back from delivery in NJ and honestly haven't played at all. Will be washing/waxing and detailing from the trip tomorrow and will check her all out. My wife says there is not storage under the seat but we haven't actually checked......others may know??
Regards,
Bob
2017 RT Agile SS
11-18-2016, 01:19 PM
#71
Not much room.
Thanks for the picture. They actually look pretty vulnerable under there
11-18-2016, 01:28 PM
#72
Be happy she decided. If something goes wrong she can not blame you
11-18-2016, 01:35 PM
#73
400 Lithium
If your style is 1 or 2 days at the most you will have no problem with 400ah. 800ah and Voltstart will not solve anyone's air conditioning concerns. When that dire common sense is to seek shore power. That is extremely rare for me as a northerner. It might be a greater concern for a southerner, but campgrounds with shore power are very common now including public campgrounds.
11-18-2016, 01:42 PM
#74
Thx and agree. We are former northerners and despite that it needs to be extremely warm before she will seek to turn on air. Heat is another issue. I need to do a bit more research on the power consumption of the Diesel Alde and or electric blankets.
The key to this entire purchase was the fact that we could store within our condo's garage. We are minimalists so the size is fine but for the difference in cash, if I had to store I would have gotten a full-sized B.
Added Note: We kept her BMW X3 till we knew the Agile would fit. Brought that to CarMax last evening. Second good experience with them. Was offered $1,500 dollars more than black book wholesale so better than we expected.
Regards,
Bob
2017 RT Agile SS
11-18-2016, 01:43 PM
#75
The batteries have heating pads so keeping them warm in cold weather is not an issue.
11-18-2016, 01:50 PM
#76
Originally Posted by booster
How about 12v native digital clock? Last time I looked, they were about $10. I assume they can be on full time whenever they have power, as they show them on the dash in the ads.
That doesn't solve the annoying microwave clock issue. When you turn your inverter on and off you also kill the power to the microwave. Then when you turn your inverter on, you get the blinking annoying control panel which requires you to reset the clock to make the blinking go away. That is the case with the Sharp microwave/convection oven I am sure Avanti has. This is the same annoyance when power goes off at your house and the many digital clocks you may have.
11-18-2016, 03:14 PM
#77
The clock on my microwave doesn't blink. It just shows a couple little points of light... not even an 0:00. Not sure if RT puts the same microwave in all units, but I know that they use it in most.
2015 Roadtrek 170
2011 LTV Libero
2004 GWV Classic Supreme
11-18-2016, 04:11 PM
#78
Actually, mine doesn't blink, either. Its just that it's SUPPOSED to show the time, and it bugs me. I am not usually all that compulsive, but for some reason, this one bothers me. The ironic thing is that I take pride in not caring what time it is.
11-18-2016, 04:24 PM
#79
I will have to check, but I don't recall our Dometic microwave blinking when the power is turned on.
11-21-2016, 02:17 AM
#80
Length-wise I definitely do but I only had ~12" of clearance around that pole.
Forget the van, let's talk about that Moto Guzz V7 Racer! Nice!
