Old 09-25-2020, 10:49 PM   #21
Here is another one in LA
https://www.rvtrader.com/listing/200...ILE-5014049747
In the whole of RVTRADER USA I only found 2.
Maybe ask around on this site, start a thread asking for a 170 .
Old 09-25-2020, 11:13 PM   #22
Originally Posted by RT-NY View Post
That Los Angeles listing looks suspicious to me -- pictures and description are too generic, no year, no miles, too cheap of a price, and what does this mean "It looks like a normal van except for the air conditioner on top"? One of the good things about the Roadtrek design is that the air conditioner is inside the cap!
Here's one in WA, the ideal model year in my opinion (the 1999 25th anniversary edition!): https://seattle.craigslist.org/tac/r...197336672.html
Yes, it looks great.
What is a 5.2 liter motor, waa thst a one off?
Or a typo?
Old 09-25-2020, 11:40 PM   #23
Originally Posted by carpeBLUEGRASS View Post
new seats
I just replaced my chev seat base foam- easy and well worth it- the backs were fine, the coverings were fine, I took the time to shampoo clean and rinse with distilled water ( to make soft, we have hard water here). the foam was worn on the sides from sliding in/out. also cleaned out old crusty grease and lubed the seat swivels.
cost will be tough for you.
there is also the winnebago rialta ( built on a VW!) which I have a fondness for- 4 different floor plans make great use of space
Off I-66 Delaplane- I'd be all over this:
https://washingtondc.craigslist.org/...202945574.html
springfield:
https://washingtondc.craigslist.org/...202927298.html
norfolk - a rialta
https://norfolk.craigslist.org/rvs/d...194066802.html
mike
Old 09-25-2020, 11:46 PM   #24
Or a typo?
The 5.2 is the old 318CID Chrysler smallblock engine. The 5.9 is a longer stroke version of the same small block engine and is the old 360CID. In a heavy vehicle, I would definitely prefer the 5.9 because of the long stroke, higher torque characteristics.
Old 09-26-2020, 12:47 AM   #25
springfield:
norfolk - a rialta
mike
Yes the Rialta's are a secret sauce for many.
If anyone needs to replace the searts, I went whole hog a couple of years ago & contacted a place Dicks;
https://dicksautoparts.com/c-1144216...oem-seats.html
https://dicksautoparts.com/c-1206703...van-seats.html
Old 09-26-2020, 12:48 AM   #26
Thank you as always Booster
Old 09-26-2020, 12:50 AM   #27
Old 09-26-2020, 01:24 AM   #28
Road Trek International- Roadtrek International - Roadtreks for Sale
Is this a treasure trove above of 170's initially & other models later?
WOW!
Old 09-26-2020, 01:35 AM   #29
https://www.shoppok.com/rv-rvs-for-s...oadtrek-170-sp
Here is another huge haul.of rigs for sale
Old 09-26-2020, 02:05 AM   #30
replace the seats, I went whole hog a couple of years ago & contacted a place Dicks;
upgraded seat base, the seat shop direct or amazon $125:
Old 09-26-2020, 02:11 AM   #31
Wow! Thanks for all of the advice and leads. I've been searching Roadtrek International, rvt, rvtrader and Searchtempest every day. 170's are definitely more rare than 190's.
While I'm leaning to pre-2000 vintage (both due to price and a desire for more of a 'classic' feel...I think a set of white letter tires would be cool!), there are probably issues going back that far: lack of airbags, parts availability, etc.
If I see one, can I show it to you for your thoughts?
Thanks again for your time.
carpeBLUEGRASS is offline   Reply With Quote
Old 09-26-2020, 02:17 AM   #32
a dodge, ford or chevy van can be fixed anywhere, by anyone with parts from napa
there are millions of these on the road- uncomplicated and not reliant on a parts supply line spanning oceans
Old 09-27-2020, 12:19 AM   #33
That is also my experience with my 1999 Dodge 170, that it is no problem to find parts or get it repaired. There are still plenty of them on the road (between the Ram vans and trucks).
My 1999 has a lot features of more recent vehicles: dual air bags, cruse control, power doors and windows, digital odometer, etc., so mechanically it is more or less a modern car even though it is also a classic. My sense is that from 1998-2003 or so, the Dodge 170's all look pretty much the same (like in the craigslist add from WA above) though I think the digital odometer starts in 1999. You can find the brochures on line to compare features by model year -- they have a surprising amount of good information in them. I have them all from 1993-2003 as PDF files if you can't find them. And, of course, always happy to give what advice I can. Roadtrek owners are a pretty dedicated group of folks (whenever I pass another vintage RT on the road they always wave hello!).
Also, regarding the 5.2L engine, as booster said: it is listed in the brochure as "5.2 L/318 CID SMPI gas V8"
Old 09-27-2020, 12:23 AM   #34
3 windows up top, always easy to spot an RT
Old 09-27-2020, 05:34 AM   #35
Have any of you resurfaced the wood you have ie; replaced cabinets to give them a more modern look ?
Or are you, like I, prefer the wood finish, no matter when the build date?
Old 09-27-2020, 12:14 PM   #36
I have solid maple cabinets fronts- nothing will last longer.
Living in the desert, each of the 9000 Robertson head screws required an 1/8 to 1/4 turn to snug up when we bought the van.
( The previous owner was confused by the Robertson heads...which are Canadian standard for furniture and electrical, he'd never snugged )
I might have a different opinion if the cabinets were laminate faced or built with engineered wood products- screws pull out or loosen up
mike
Old 09-27-2020, 01:02 PM   #37
When everyone is talking about solid maple, oak, cherry, etc cabinets do you really have entire cabinet made of those material? I think most of the manufacturers use the lightweight vinyl covered plywood for the frames. IIRC all the class b's we looked at were that way with only doors solid. Our 07 Roadtrek 190 also was listed as solid wood cabinets, which they are except the surface of the frames are vinyl that matches the wood color until they both age a bit. Only the doors and some trim are solid wood.
Old 09-27-2020, 04:50 PM   #38
Yes, you are right- everything where hinges or hardware attaches is solid maple- all the doors and fascia. The screws get a good bite.
everything lining the interior walls of the van appears engineered
as are the cabinet "boxes" with a mix of maple veneer on the cabinet interiors- and a contact paper on the inside of the head and galley backsplash
Old 09-27-2020, 07:32 PM   #39
For the OP, re Dodge 170 model year desirability and such.
You may want to look at this site, which is the old Yahoo board after moving to a new host.
https://roadtrekkers.groups.io/g/RT/topics
There are lots of Dodge owners on there, including some 170 owners. Good representation of a wide range of model years compared to most places.
The does seem to be some evidence from users that the 1998 and up model years, which were after a redesign, have more handling issues than the earlier years. All Dodges can be kind of random on handling, with some described as scary and some described as good.
Old 09-27-2020, 07:44 PM   #40
So in this photo of my modified TV Cabinet (had it cut back to an omly 9.75 inches), the mortise corner hinge is sold maple.
The base is maple plywood.
The face solid maple.
The frame itself is the vinyl covered ply.
My upfront cabinets are 3/4 maple plywood with maple trim - couod have gone with 1/2 but ...
