Old 10-19-2018, 03:19 AM   #21
Only a 28 amp charger?
Old 10-19-2018, 03:34 AM   #22
Charger current is configurable and I think this label simply shows the factory settings. I will need to check if it can be set higher.
But considering the battery capacity is 105 Ah, 28 A would not be appropriate? If I remember correctly, I read that charge current should be 30% of the battery capacity.
Old 10-19-2018, 03:38 AM   #23
At 105, yes it would be OK. I thought someone had mentioned it was a 185ah battery like used in the Zions.
Old 10-19-2018, 05:15 AM   #24
Originally Posted by Yoshimura View Post
You have more information about this? I would really like to have temperature compensation. You have a part number for the sensor?
Here is what I got back from Sigineer. It includes a link for the temp sensor.
Hi there
Good day.
This is Franklin from Sigineer Power.
Thx for your inquiry.
We are a professional Chinese OEM manufacturer of Inverter/Charger, DC
to AC Power Inverter with some models conforming to UL458 , UL1741,
ETL or CSA .
We are selling inverters worldwide, offering OEM/private label for
difference brands.
here is the link for battery temperature sensor
https://www.sigineer.com/product/bat...rature-sensor/
Our accessories can only be used with our inverter chargers..
Did you buy our models before ?
Waiting for your reply.
Your sincerely
Franklin Chu
Sales
SIGINEER POWER LIMITED
Add: Bld A, Jiali Industrial Zone,
Yuanfen Rd, Longhua, Shenzhen, 518100, China
TEL: +86 755 2160 7078 Ext 6
FAX: +86 755 6165 8278
Email: franklin@sigineer.com
Skype: franklin.zhu
Whatsapp: +86 18998080464
Website: www.sigineer.com
Should you have any more questions or interest for our products , pls
let me know.
Your sincerely
Franklin Chu
Sales
Skype: franklin.zhu
On Fri, Oct 19, 2018 at 8:33 AM <cruising7388@aol.com> wrote:
> What is the part number for the temperature sensor and cable for the Powerstar 2000 Watt 12 volt inverter/converter and where can it be purchased.
Old 10-19-2018, 12:50 PM   #25
I referenced the peculiar charging requirements of the Northstar battery as a possible solution to the odd voltages Yoshimura has seen.
It turns out that Yoshimura doesn't have a Northstar battery. Deka batteries are in the coach. Yoshimura could let us know how many Deka 8A31DT batteries are installed.
The charge profile labeled "Sealed lead acid" in the Signeer manual: 14.4V charge, 13.6V float - looks like it is the best overall match. The AGM 1 profile as a summer setting and AGM 2 setting in winter is another option.
With a 28A output the charger doesn't match the specs in the Signeer manual so it is likely a different brand. There are many different brands of these low cost inverter/chargers that look exactly alike.
If the coach has 4 AGM batteries then a 28A charger is undersized.
When these RV's come off warranty I think we'll see some nice modifications such as installing top tier programmable inverter/chargers that are easily made to match any replacement battery you end up installing.
Old 10-19-2018, 01:41 PM   #26
There is only one battery and it's located under the van. Thanks for your comments.
