Old 01-01-2020, 10:43 PM   #21
The work was done at Courtesy Ford
Papalee is offline   Reply With Quote
Old 01-02-2020, 01:52 AM   #22
Default Wandering E250
OK, it is unfortunate they didn't give you a copy of the alignment printout, they are pretty interesting to see, and a valuable record.
You might give them a call and just ask for it from their records, that would be an interesting call and certainly not out of line. Since you paid for it they actually owe it to you to provide it. Especially if you told them about your difficulties keeping it going straight.
Knowing the actual numbers for those three alignment parameters is pretty important, it would help establish where the van is at now, given it still has issues. Did you notice any improvement after this work and the new parts were installed?
Your van has very low mileage at 38,000 I have to say, that is remarkable if it is accurate. Perhaps you know some of it's history, and it does look really good in your photo.
I'm suspicious the biggest issue may be in the alignment numbers, and that is why I wanted to see where is set. The 1991 and earlier series has the kingpin frontend which is not so easy to correct driveability problems on if alignment related.
You may already know all about this.
When the 1992's came out they changed over to ball joints on the E Series frontends, and made provisions for changing alignment settings relatively easily as needed, whereas the kingpin version is to a great extent fixed by the two front axles themselves with no simple adjustments other than the toe settings. Perhaps I just haven't found the answer yet for this, I don't have a manual for the pre-92 models.
You aren't the only one who has had wandering problems with the E Series vans..... My 1992 Falcon did the same thing as yours and I have pretty much solved that issue, and the alignment was the key for me. I didn't have worn parts but I was able to adjust it myself and prove the fix. That was where the balljoint frontend paid off for me, and why your situation may be somewhat different as far as the way forward regarding alignment.
You may have some other wonderful frontend options available. I'm looking at that as well.
One more question for you, have you weighed your van when loaded up, front and rear separately, to know the distribution and the total? That would be important when you begin discussing the tires you have now and changing them, just from a capacity point of view alone.
I did respond to your Friend request, I'm new to this and don't know the ropes....
Wishing you a Happy New Year Papalee....
Paga is offline   Reply With Quote
Old 01-02-2020, 04:25 PM   #23
I did a car fax on the rv and there were some old records from the last owner with his phone number. I gave him a call and talked with him about it and found out that the rv was bought new by some women that would drive it from Medford to Bend and back one time a year.
He the told me he would drive it to a near by lake about two times a year.
As for weight I called Cooper tire and they also asked what the weight was, but I had already winterized the rv so I am going to gas up ,water in the tanks, ect and go to a truck scale this spring. And to let you know that there is a Face Book group for Intervec owners.
Old 01-02-2020, 06:25 PM   #24
I don't know if this is relevant with your particular RV. I have a 97 PW on the Dodge 3500 chassis. If an alignment is done with the Dodge 3500 specs it's off from what PW recommends. Their values are different from a Dodge Ram van. They caution you to use their specs. A good alignment shop probably knows this.
Old 01-02-2020, 06:59 PM   #25
Beyond that point, even, is that a GOOD alignment tech will be able to drive the vehicle and come up with the best settings to make it drive the way the owner prefers. Those setting will often be much different than the spec calls for. You have to remember that the spec for a van has to cover a full range of use from empty to full capacity, so they will be a compromise most of the time in normal use. When you have a B conversion, the weight and distribution has very little variation by comparison, so the settings can be dialed in to better match the use with no huge compromises.
Factory specs are often set very wide so they are easy to build and still be in spec, and you can have vehicle that handles horribly that is still within the the limits, or "green" as they now say based on the machines.
Old 01-08-2020, 05:36 AM   #26
Default Wandering 1991 E-250 Falcon 190
Papalee,
Sorry for the delays in getting back to you but it took some time to answer some of the questions I had about your 1991 E250 frontend. The first thing I looked at was whether the 2008 and up complete E350 front axle assembly, with the much larger disc brake rotors and calipers included, using an all brand new conversion takeout from a 2018 or 19, would fit into your van.
One of these would also have ball joints, which makes the caster and camber adjustments possible and fairly easy to do. After I resolved my wandering 92 E250 problem, I went ahead and had this frontend upgrade done in 2016, and did the same alignment correction to the caster on the new front end.
So I a new 2016 E350 frontend with less than 100 miles on it in my 92 E-250, with far superior brakes up front as the icing on the cake. A huge improvement that was frankly inexpensive.
This would have been a wonderful upgrade for yours, at a low cost for the complete setup including professional installation, here in Portland.
Unfortunately the frame rails on the 1980 thru 1991 E-series vans are narrower, and so that rules out this upgrade.
In parallel with that investigation I also looked into what parts were available to add the ability to increae your positive caster given there is no adjustment provision on your kingpin frontend. I found a aftermarket bushing that is installed in the bottom of the radius arms under the axles, an eccentric bushing which then allows the positive caster to then be increased up to 4 degrees.
The good news in this is that if caster is the primary issue with your wandering E-250 there is a solution that is inexpensive.
Have you had any luck getting the alignment readings from your shop ? If not that is something we could do on a level surface with some tools I have. It's not difficult to measure your toe, camber and caster yourself.
If we did that, or a shop did it, at least we'd have a baseline of where the frontend alignment is now. Increasing the positive caster often results in improved forward stability, which means the wheels want to track straight and not wander or follow ruts. The steering wheel will return to center when you let go of it after a turn, which is part of the improved stabilty we really desire.
I have proven all of this to myself without any doubt on my van. I could not believe the improvement I saw, it was the first time I had been able to completely relax driving my van at freeway speeds, passing and being passed, and in wind situations in general. I increased my positive caster using aftermarket adjustable camber/caster bushings I personally installed in my top ball joints in place of the OEM bushings.
So exploring this possibilty may benefit you as well, that of increasing your positive caster.
Here is the post I read when I began searching for solutions to the wandering, like you are. The poster is a fellow named Harvard who had the same problems with his E-450 RV. This is well worth reading if you haven't already:
E350/E450 Handling Problems are caused by too little + CASTER
Well, this is a long reply to you, but perhaps it will be of some help. If you'd like we can get together for coffee sometime and talk in person. I'm in SE Portland and I think you are in the metro area as well.
Regards, Paga
Old 01-08-2020, 05:54 AM   #27
This should have read:
So I had a brand new 2016 E350 frontend with less than 100 miles on it in my 92 E-250, with far superior brakes up front as the icing on the cake. A huge improvement that was frankly inexpensive.
Also, regarding the eccentric caster bushings I found that would work on your 1991 E-250's radius arms, it claims to be able to add up to an additional 4 degrees of positive caster beyond what you have now. So if you are at 3 now, you could go to perhaps 7 degrees positive.
I'm running basically 7 degrees positive in my 1992 E250 with the new 2016 E350 frontend installed. When I increased the caster on my original 1992 frontend from 3.5 or so to 5.5 the improvement was dramatic. I used a bushing with even more adjustment in the 2016 frontend to acheive the 7 degrees I run now, with great results.
Paga
Old 01-08-2020, 06:54 PM   #28
I checked with Courtesy Ford and they had NO record of the numbers, called Les Schwab
and talked to one of their technicians and found out that they have numbers in the machine
But they can adjust as needed. He also said the steering problem could be the tires.
I would like to get together some time soon as I get over this cold.
Old 01-08-2020, 09:44 PM   #29
Originally Posted by Paga View Post
Papalee,
<snip>
<snip>
Regards, Paga
Wouldn't it be nice if this guy Harvard was universally correct that the only way to cure handling/wandering problems is more positive caster? Unfortunately for many folks, loose parts/steering box and/or poor toe/camber setting and/or tire inflation problems can contribute. More caster may help the situation but is in no way a "cure-all" for what ails you, as some of the old elixirs promised. YMMV.
Old 01-09-2020, 03:33 PM   #30
I should have added to the list above: weight distribution. If you have too much weight in the back, it tends to raise the front. Even if the alignment has been done in this position/configuration/distribution (which of course changes a bit as you use fuel, water, etc.), the (temporary) front end geometry changes (toe/camber/caster) that occur as you encounter wind/ruts/bumps/curves (and these unfortunate changes are a necessary evil with any suspension; if you have insomnia some night, you can Google "bump steer" and "roll steer"), can be different to what they would be if the front end was at the design height (although I doubt this is as serious an issue with the twin I-beam front suspension rather than the much more common double A-frames). Along with this is the issue of having the suspension aligned when relatively unloaded, and then how that changes when the vehicle is then fully loaded (in whatever is your typical traveling arrangement is).
In my opinion, a lot of darting/wandering problems are caused by toe-out, rather than the correct toe-in. A small amount of toe-in is specified so that when the vehicle is traveling, and the necessary "slack"/looseness in the suspension allows things to move slightly (absolutely necessary, otherwise the entire frontend would be frozen), so that the front tires are essentially straight as you drive down the road. What happens with toe-out (or possibly, excessive toe-in) is that as you encounter wind/ruts/bumps/curves, one side of the vehicle is loaded more than the other, and that front tire takes over and steers the vehicle that way, and vice-versa. A good way to tell if the toe setting is wrong is to carefully check the tires. Here is one link to tire-wear-vs.-alignment, but you can Google many others: https://www.knowyourparts.com/techni...ing-tire-wear/ These charts can also help diagnose other alignment problems. Of course, they don't show up two blocks from the alignment shop, so you need probably hundreds of miles to form them, and of course maybe longer to "erase" the old ones, although they may never really go away.
Good luck, Dick
Old 01-09-2020, 03:56 PM   #31
All of what Dick has been saying is right on, and the fact that so many individuals and shops immediately point to the same solution for all the problems is very disheartening. Suspension, steering, handling is a dynamic and always changing thing going on and there are lots of parts involved that can cause the issues. It takes experience and thinking to work through the tougher issues as just throwing "cures" on it rarely works.
The cheapest and easiest improvement is often toe setting. As Dick said, toe out can make it like herding cats to drive. You can do it in your own driveway with a tape measure, piece of chalk, a nail, and a jack.
Of the list that Dick had, I would add that cross weight, or wedge as the racers call it, can also be added right with front back weight, although it usually would cause pull rather than wander.
If the van does have the twin I beam setup, they can be aligned, but it ain't easy. It takes a frame shop with a frame pulling rack to do and involves bending the lower control arms. I have seen it done, way back around 1985 and it wasn't pretty. On one pickup the control arm broke, loudly. They welded it back together and continued.
The need to find an old school, truck focused, shop, is very important in stuff like this, as all the newer machines will spit out is numbers and the techs don't have much of a clue what they mean.
Old 01-09-2020, 10:39 PM   #32
Trying to answer your last email but something is not working, anyway Iwill get a hold of you when the weather gets better, I also wanted you to know that I live over by Mall 205
Old 01-09-2020, 10:44 PM   #33
OK, sounds good!
Old 01-10-2020, 02:26 PM   #34
DaveBad's Avatar
Default Castor and Stabilizer improved my ride a lot
Papalee,
I have a 2008 GWV built on a 2007 Ford E350. I bought it used 3 ½ yrs ago with 32K on it. In my case I did not have any “wobble” but the steering was very influenced by grooves in the road. Also the steering would not “return to center” leaving me having to drive with both hands on the steering wheel constantly making corrections. Very tiring.
I know there are many pieces of the mechanics that are involved in the handling but in my case increasing the castor made all the difference in the world. I had my local mechanic install these and increase the castor a couple of degrees and now the van steering returns to center.
https://www.amazon.com/dp/B000COBT68
The other problem I had was that gust of wind and passing tractor trailers pushed me all over the place. Quite scary. After doing a lot of research I purchased a steering stabilizer. It turns out that there never was one installed on my van which surprised me since it is such a heavy vehicle. Installing the stabilizer also made a huge difference. Now when a truck passes me I feel a gentle push instead of a hard shove. I know longer need the “death grip” on the steering wheel.
https://www.roadmasterinc.com/products/rss/reflex.php
DaveBad is offline   Reply With Quote
Old 01-10-2020, 05:33 PM   #35
My rv is to old for that type of bushing, and I am planning on a steering stabilizer this spring
