12-05-2014, 01:51 AM
#101
Re: Roadtrek is making a ProMaster model... Zion
Originally Posted by bobojay
Since the ProMaster diesel is now available, I wonder if RT is going to offer it as an option? Winnebago announced today that they were going to offer it in the Travato & Viva/Trend models...
This unit will be a winner for RT I'm sure....
wouldn't a diesel engine cut cargo carrying capacity further. they can barely meet weight as is. but i don't know
12-05-2014, 11:43 AM
#102
On the deisel, the fuel tank could be smaller to even out the weight difference, but I don't know. Also it's displacement is smaller than the gas engine and the tranny is different, so maybe there is no weight penalty.
Interesting on the spare. Even these small 16" wheels need a lot of space under the van! In the vid, they show pulling some kind of kit from under the seat. My van, of course, doesn't have this. I wonder if I even have a jack or lug wrench on board??
12-05-2014, 03:10 PM
#103
wincrasher-
2 things have occured to me.
1. this might be the 139 wheelbase or the 159 wheelbase-20 feet 7 inches. the 159 wheelbase extended to 21 feet will probably leave the tire in the same spot so more back end.
2. and this is my fault. Jim Hammill did say there would be a spare tire option and that the tire would be under the van. he did not say- i did not ask-if it would be the same underfloor mechanism. there are other under floor tire holders made- i just assumed.-sorry
12-05-2014, 05:52 PM
#104
How many Class b's have been made with door mounted or bumper mounted spare tires in the past ? Is there some sort of engineering problem pertaining to the Promaster that precludes this simple,tried and true solution ? I have never liked under chassis spares and much prefer (through life experience) bumper or door mounted spares .
12-05-2014, 06:04 PM
#105
I've always hated the look of back end mounted spare tires other than on the original Jeep. Just my thing I guess. I've never bought a vehicle of any kind with a tire mounted on the back.
12-05-2014, 06:11 PM
#106
maybe promaster will have no hitch on roadtrek version. still need more info
it does not have great tow capacity
12-05-2014, 10:34 PM
#107
I'd guess it has something to do with clearance. There isn't much room to mount stuff under a PM, although without the rear driveshaft, one does gain space where that would be, so stuff could be shorter, but wider underneath.
12-06-2014, 04:05 PM
#108
Looks like zion is mostly white melamine particleboard. it is heavy
12-07-2014, 02:38 AM
#109
I've always heard that part of the door mounted spare tire issue is that the door structure and hinges weren't engineered by the chassis manufacturers to carry that extra weight.
Our first B, the Lexor had a door mounted spare, and I hated it. The looks, the extra weight hanging out there, just made me nervous every time I had to open and close that door
Bob & Sharon
12-07-2014, 02:55 AM
#110
I have only used a spare once in my 20 years of driving. I hate rear door mounted spares. I would rather risk spending a little more time accessing under the van in the rare case I needed a spare, rather than have the hassle of a spare adding extra length and an ugly look to my van.
12-07-2014, 02:58 AM
#111
Road trek actually has a system that they have used on their other vans that supports the spare off the receiver. I'm sure it can be adapted for the Promaster if there is demand for it.
Pleasureway in the past has just bolted their spares to the back doors without regards for the manufacturer's warnings about the limits to the door structure and hinges.
Just one thing to consider when comparing vans I guess.
12-07-2014, 03:14 PM
#112
I'm not getting a spare. I didn't have one with my Great West Van Legend. I couldn't change it myself if I wanted to. So, I look at it as an event like a fender bender. Just live with the inconvenience that will come. I've got time. I drove 10,500 miles on our Alaskan trip including the gravel pothole filled On Top of the World highway from Chicken, Alaska to Dawson City, Yukon. ::: egad i just said some famous ha ha i told you so last words :::
12-07-2014, 03:40 PM
#113
[quote="Davydd"]I'm not getting a spare. I didn't have one with my Great West Van Legend. I couldn't change it myself if I wanted to. So, I look at it as an event like a fender bender. Just live with the inconvenience that will come. I've got time. I drove 10,500 miles on our Alaskan trip including the gravel pothole filled On Top of the World highway from Chicken, Alaska to Dawson City, Yukon. ::: egad i just said some famous ha ha i told you so last words ::: [/quote
i probably would not attempt to change the tire myself. however having the tire makes it more likely a tow truck could take care of you at the site. i would worry about it-what can i say.
12-07-2014, 04:39 PM
#114
Originally Posted by Davydd
I believe Booster has 240 watts of solar on his Roadtrek. He might be able to address the solar better than anyone here. After I went through all my gyrations I came to the conclusion that with our second alternator and frequent driving that solar was mostly frosting. If it would make up most of the difference of the power usage of a compressor refrigerator running all the time I would be happy. But then I have no experience with photovoltaic solar. I will know more by next spring.
Four group 31 AGM batteries would weigh about 270 lbs. + or -. That would be about 150 lb. premium over lithium ion.
Our experience with 400w solar and 190Ah stored in two 6 volts AGMs is working well to keep our two 12v compression fridges running for weeks and all the electricals in our Safari Condo without shore power, as long as the van is in an open space and it doesn't rain for 4 days. But a B moves more often, just driving it 30 minutes every two days tops it off. I'm sure the lithium batteries could store it more efficiently but the whole charging system has to be equiped and tuned differently. I'm glad Advanced Rv and Roadtrek are trying out those systems.
And yes "mutcth" the two living zones in the Safari Condo layout are more appealing then the Zion layout.
...I like a lot about this design, but I'm still partial to the Safari Condo Flex layout, especially for its additional seating area/"living room" up front....
No wonder 90% of european layouts in the (6.4m) 21' long Fiat Ducatos are adopting this layout, pionnered by Adria 15 years ago. But this layout dosen't appeal to all, due to the tight corridor between those areas. In some european layouts, a middle shower area that temporarely uses the corridor, helps to have a wider passage.
I'm glad Roadtrek's very conservative interior design is finally being adressed, although they have a long way to go with the north american rv market being presently so primitive in terms of esthetics.
The 400w solar array on our ProMaster.
12-07-2014, 04:46 PM
#115
I can't imagine getting a 16" truck tire would be a problem anywhere in North America. It's a very common size.
But if having one along is a high priority above, well it's just one more factor to differentiate the brands:
Winnebago - forget it, no room. But you'll get the pleasure of having a noisy Onan generator!
Pleasureway - maybe, hung off the rear door. You'll still have a genset and a 2 battery box.
Roadtrek - yep, underneath, but you won't have an onan generator.
Or you can buy what you like, and find a mounting bracket that hangs off the door or a swing arm bracket on the receiver hitch. Or get a storage box for the receiver hitch and put a tire in there as well as a bunch of your other "must haves" you want to carry. There's downsides to those choices as well.
12-07-2014, 05:23 PM
#116
..... I drove 10,500 miles on our Alaskan trip including the gravel pothole filled On Top of the World highway from Chicken, Alaska to Dawson City, Yukon. ::: egad i just said some famous ha ha i told you so last words :::
I was up there this past summer. The last 10 miles before you reach the Canadian border on the Top of The World highway are now paved. I did carry a spare and was prepared to change it myself if needed because there are plenty of areas in Alaska where you won't be able to call for help.
- - Mike
2013 AS Interstate on 2012 MB Sprinter 3500 Long & Tall
12-07-2014, 05:49 PM
#117
the zion has swivel seats and a hole for a table in between the seats. the passenger seat in my opinion would make a separate section for one person with the other in the back. just my opinion
12-08-2014, 12:05 PM
#118
Ugly rear mounted spare ? Vans are ugly and Promaster's are even uglier. A rear mounted spare won't change that by much. When needed, a spare tire can become a beautiful thing.
12-08-2014, 04:14 PM
#119
Easy there. Let's not get into a "who's van is the ugliest" debate.
12-08-2014, 04:43 PM
#120
I remember some years ago when my wife and I decided to buy a van and I suggested a Chevy Astro. My wife said " No. Those are ugly " ????? I don't see how anyone can look at a van and think " That's beautiful " . It doesn't mean I don't love my van. I love her for whats on the inside. Oh BTW. Guess who didn't buy an Astro van.
