Old 04-25-2012, 03:11 PM   #1
Default Michelin Tire PSI Inflation Table
I need some help with choosing the Tire PSI for my Michelin LTX/MS2 LT245/75R16 E
I'm using data from these sources:
MICHELIN Truck Tire Data Book
http://read.dmtmag.com/issue/58068
and here
http://www.michelintruck.com/assets/pdf ... taBook.pdf
Last time I checked my van weight it was:
Front: 4020 lbs
Rear: 3860 lbs
(not fully loaded)
So if I plan based on 4200 lbs front and 4600 lbs rear what tire pressure would you use? In the past I have done 60 or 65 front and 80 rear.
From the Michelin charts it looks like I could 50 psi front and 60 psi rear for soft ride. Am I missing something?
Would you go that low?
Old 04-25-2012, 04:43 PM   #2
Default Re: Michelin Tire PSI Inflation Table
We are currently going through the same drill. We upsized our tires to 265-75-16 and changed from Bridgestone V-steels to Michelin MS2s. We found the Bridgestones to handle best at 65/80. We only have one test run on the new tires, run at 60/70, so we aren't done yet. Next test will be at the 65/80 to see how that compares. The Michelins do seem to be more comfortable to this point.
Nearly everyone I have ever talked to has found the Michelin recommended pressures to be too low to get decent handling, especially in trucks.
