Old 02-19-2018, 06:01 PM   #1
Default Lithium and AGM combo system like Hymer
OK, time for a hairbrained idea for those that have AGM batteries (or wet cells) and face the common issue of getting them to 100% full periodically because they take 6+ hours to complete the last 20% of the charging.
The thread about the new Hymer lithium/AGM that is touted as being a true shared system brought all this up.
Many of us have skeptical of having AGM and lithium in parallel, but maybe it could be made to be a good thing if used correctly.
Fully charged AGMs will be at about 13.1v right off a full charge and lithium will be substantially higher at over 14 volts for a long part of their discharge cycle. Obviously, the lithium will carry the load first due to it's higher voltage, but it will also be charging the AGM as the voltage is high enough to do it fairly well.
Certainly have no details or if it would even work, but just as a starting point consider a normal 2-3 hour driving time with both the AGMs at under 50% and the lithium at low cutoff. In that time the AGMs would get to about 80% and the lithium would get full. If the lithium is sized to be 20% of the AGM capacity, plus whatever power you normally use in about 6 hours, it would finish the charging for you and eliminate having to be on a charge source for long periods. Many of us use solar for that now, but as we all know solar can be spotty for the longer times needed due to locations and weather.
Doing the whole thing this way might be a way to get a lot lithium benefits without the very high cost of getting large capacity, and also retain cold weather capability with high capacity. Do to the normal weight limitations of carrying lots of AGM batteries, it would likely be good up to about 450ah of AGM with 100ah of lithium, although 300ah AGM and 75ah of lithium, or less, would probably be fine for many. For those that stay off grid for long periods without anything but the van alternator and maybe solar, this could take away any worry about if you are getting your AGM batteries to full periodically because of the long topping off time, if I am thinking straight and cost much less than going all lithium. It would also make it easy to remove the lithium battery in very cold storage if chose to.
It is kind of the mirror image of how the Hymer setup is.
Very odd, but kind of an interesting premise for the right applications.
Old 02-19-2018, 07:34 PM   #2
This actually isn't totally obvious to me. The statement that the two batteries are at different voltages can't be literally true. If you have two batteries connected together, you only have ONE circuit, so there can only be one voltage, no?
I am not saying you are wrong, only that it isn't obvious. My feeble EE intuitions fail me when it comes to how such a system would behave. A very interesting area for inquiry and experimentation, though.
Old 02-19-2018, 08:22 PM   #3
I think, and I stress think, is that as you say, you would wind up with a voltage that is common to both (assuming low resistance connection) and be determined by the acceptance of the AGM and discharge resistance of the lithium, much as it does when you have a charger that is lower in capacity than the acceptance of the battery are absorption voltage. Thus the same as the bulk charge stage with slowly increasing voltage as AGM gets charged. The good is that the lithium should hold high voltage through almost of it's discharge curve, so more or less a constant voltage source through the whole process, but getting pulled down by the load possibly in the beginning. Certainly would need to be tested and evaluated to find out what it really does. I can imagine it being similar to putting one of the lithium jump start batteries on you car with a mostly dead car battery.
Thinking more about it, the setup might also be very good for boondockers that have an Onan, but only run it long enough to get to 80% on their AGMs because they don't want to run the Onan for 10 hours to get a full charge. Many likely never get to full on their batteries. They would run long enough to get the AGMs to 80% and the lithium full and shut it off and let the AGMs fill to 100% off the lithium. If they then chose to, they could do an even shorter run to fill the lithium again. The very same thing would work on boats where nearly always charge to only 80% so the engine is run so much.
Hopefully, we will get a bit of feedback from some others to see if they see any holes in the thought process, as it pretty obscure to visualize all that would be going on.
It probably could be tested on the bench with a small AGM and one of the jump starter lithiums or other small lithium.
Old 02-19-2018, 08:32 PM   #4
It is certainly true that with the batteries connected in parallel the voltage across each will be identical and the current division between them will be governed by the apparent resistance they present at their respective terminals. As the batteries receive charge their internal impedance will change in accordance with their charge curve. As the AGM approaches full charge its internal impedance will rise sharply and the bulk of the current will be going to the Li cells. As long as the charging source maintains a voltage sufficiently high to bring the Li cells to full charge everything will reach 100%. At that point the AGM will be overcharging but the current will be quite low, hopefully low enough that it does not damage the AGM. When charging stops and everything settles out the voltage will hold at the higher Li and some current will be flowing into the AGM. If the batteries are separated and allowed to stabilize the voltages will be in accordance with the characteristic of each chemistry.
At least that is the way I see it.
John
Old 02-19-2018, 08:35 PM   #5
Reading Boosters second entry I see his logic with regard to charging from the Onan. When you get the Li cells to 100% you shut the Onan off and allow the Li cells to slowly bring the AGM to 100% on its own.
Old 02-19-2018, 08:44 PM   #6
John
I think the AGM will not overcharge unless it is already full when the charger is connected as the lithium will be far and away quicker to get full. The risk of long term overcharge on the AGMs would be if the lithium still had enough power in it to maintain a higher voltage than about 13.5v after the AGMs were full.
In the real world, I think I would set it up so that there was a disconnect between the AGMs and the lithium, with the charge sources going to the lithium. In everyday use where you would be getting charged enough to live off the lithium, or even mostly, you get the AGM full and shut it off and live off the lithium until the AGMs are needed. This would also shorten the recharge time on the lithiums and give way less charge cycles.
Old 02-19-2018, 08:56 PM   #7
Now someone needs to test this hypothesis with an AGM and small Li batteries and a couple of ammeters. It could be done on a small scale using something like a motorcycle AGM and, say, a 45 AH Li battery.
Old 02-19-2018, 09:50 PM   #8
And be sure to include a fire extinguisher and 911 on your speed dial
Old 02-19-2018, 10:01 PM   #9
In reality it would be very close to what you have, just with the relative battery bank sizes swapped!
Old 02-20-2018, 03:27 AM   #10
OK-I'm gonna bite. 20ah Lithium batteries are available for $100, less on Alibaba. That would be a good match for an 80ah flooded lead acid and two of them a match for 225ah lead acid.
Assuming I do that what voltage should they be charged at and any other relevant info I need before becoming the guinea pig. Also assuming I don't burn the thing down.
I would put a manual switch between them and maybe a second battery monitor.
Harry
P.S. It charges at 14.4volts. Charge the two batteries separatly, combine them to top off the lead acid, separate to use the lead acid battery.
Old 02-20-2018, 03:48 AM   #11
Harry
20Ah at what voltage?, it is best to use Wh which incorporates voltage to the equation and allows for apples to apples comparison. 20Ah at 12V = 20 X 12 Wh = 240Wh. In fact, Ah is a meaningless unit but became common for 12V batteries.
Old 02-20-2018, 04:14 AM   #12
I edited my previous post:
I can't find the watt hour rating but I don't think I really care. They call it 25ah. I'd just like to see if it would top off a lead acid battery. I'm open to all opinions since you guys know more than I do.
Harry
P.S. Assume I have installed the battery. How do I determine when it is almost charged and can separate from the lead acid battery. Do I need a second battery monitor? Is there a cheaper way to do it?
Old 02-20-2018, 01:03 PM   #13
Harry
I think the 14.4v is fine, although it is likely that the small lithium will be different chemistry than the what is used in our vans. I would be sure to check to see what the charging procedure is for the lithium because it likely won't have any overcharge protection built in and some chemistries can burn or explode. This is probably the most difficult parts of the test. If you could find a battery that came with a matching charger it would be well worth the extra couple of bucks. If you could find a small LiFePo4 chemistry even better. With low cost Chinese lithiums I would be sure to charge away from the van, or even outside..
You should be able to determine the approximate 80% point on the wet cell by watching the voltage and current and then confirm with a hydrometer. The voltage will rise during the bulk stage until it hits the absorption setting of 14.4v and then quit climbing. That is probably at about 70%. The current will hold steady at that point for a little while or very slowly go down. I think I would let it run for about another 30 minutes to an hour watching the current. If it starts to drop quicker, stop at that point. Check the SOC with the hydrometer. Once you know what the amps are at 80% you should be able to repeat the procedure more easily.
Sounds like an interesting adventure! Keep us updated and how it goes.
Old 02-20-2018, 02:52 PM   #14
It’s lithium ion and lithium Ion polymer that are dangerous to overcharge causing s runaway reaction.
In my experience abusing LFP, overcharging then causes them to vent and release an odor and become an open circuit.
These were A123 cells.
They got a big hot but not dangerously so, though enough to burn skin if you grabbed them at peak, though a minute later they were touchable.
Technomadness is offline   Reply With Quote
Old 02-20-2018, 02:54 PM   #15
Hybrid only seems to make sense if you are using a generator to charge regularly and want to minimize generator running time.
With solar there’s no advantage.
Lifetime cost of LFP is cheaper than AGM.
Old 02-20-2018, 03:03 PM   #16
I just did some quick looking on ebay and a 10ah LiFePo4 is about $100 cheapest. Most of them list 14.4v charging so right on with AGM there.
If I were to do AGM for the test, I would then get 40ah of AGM in a 4 pack of the 12ah batteries. These are the same as we have in our security system (2 or them) that are getting near the end of their life anyway. About $60 on ebay.
Most of this stuff is likely coming from the same place as the Alibabba stuff, and Alibaba would probably be a bit less expensive.
The least expensive on ebay looks like it would be to get a 3ah LiFePo4 for about $40 and one of the 12ah alarm batteries for about $20.
That starts to get tempting just to satisfy curiousity. A bit small for max accuracy in measurements, but would likely be OK for a works/doesn't work test.
Old 02-20-2018, 03:18 PM   #17
Keep us up to speed if you decide to do it.
Old 02-20-2018, 03:24 PM   #18
At the moment I'm thinking of going high dollar with a Smart Battery with BMS and put it in the class C RV with 225ah of flooded lead acid. Haven't decided whether to use 20ah or 25ah. Gotta check space available as one is 3" wide and the other 4".
I ordered a high current DC switch. It looks to me like I need a coulomb counter for the lithium. Money wise things go outta sight pretty quick!
I can generator charge to 85%. Gonna wait a few days to let the thinking and advice settle down before ordering the battery. There is a 20ah battery with BMS for $175, not Smart brand.
Old 02-20-2018, 03:32 PM   #19
Yeah, at $60, it is probably worth it for it's entertainment value. People around here spend more than that renting an ice fishing house for littel while
Old 02-20-2018, 04:04 PM   #20
I just ordered the 3ah LiFePo4 and a 12ah mobility cart AGM on ebay. Both in stock in US (claimed) so no super long weight like the direct to China can be.
Splurged on a 5 star rated AGM, so total was $68 with free shipping and no tax.
It should be interesting, and very appropriate that that there is a fire extinguisher thread going on at the same time Cruising7388 would be happy to know I have at least 3 extinguishers in the shop/garage.
I think I will have to find the 80% point on the AGM by doing a guess on amps to it, then letting it rest and checking no load, rested, voltage. Once I do it the first time, I should be able to go by what ever current it took at 80% for the future which displays on my bench charger. The lithium, I will just charge to 14.4v with relatively low current and stop. I will start out charging them separately to just test the premise of the lithium filling up the AGM, and then if that does work start looking at how they react to being charged together.
