Originally Posted by Photog
Originally Posted by Mike
Somewhere on here I had a discussion about tire size, going larger diameter, to reduce rotations
per mile, and to try increase mileage, but I'm darned if I can remember where it is.
Feel free to resurrect it if you can locate it.
I think I found it. I did a search for "tire size MPG".
viewtopic.php?f=9&t=1258
I sent some emails and did a bit of research, probably prior to last Spring when I got the new
set of standard sized tires. I believe the costs of switching to a slightly larger tire size wasn't
recoverable over a reasonable amount of distance and time. Nor was it recommended or safe.
Were the larger tires that much more expensive than the stock size?
Did you notice any MPG improvement, when you switched to Michelin tires?
I sent letters to local GM Dealers, as well as GM Canada, describing what I wanted to do.
The main issue was having to not just buy the larger tires, but also the appropriate larger rims, and I believe
there were some other concerns regarding turning clearance inside the wheel wells. When I looked at the info
I'd gotten back, the mpg increase would be marginal, I don't recall exactly how much, but it was less than a 3% improvement.
I decided to go with Michelin AT/2 (more aggressive tread pattern than MS2 series) with OEM specs. I like them, they
ride nice, I try to keep them at 80 psi rear and around 65 psi front, for improved stability and mpg reasons. I think they
help, although again, no idea by how much.
