Old 05-18-2023, 04:33 PM   #21
For "siting" the location. I planned on using a magnet on the inside of the fiberglass, and a large washer outside. Also made a template of the size for inside and out. Wound up just using the cardboard templates - and lots of reference measuring. Then drilled a small pilot hole to make sure there was plenty of clearance. Happy with the end results.
Best of luck.
Cheers - Jim
phantomjock is offline   Reply With Quote
Old 05-18-2023, 05:15 PM   #22
I'll add, mine is a 170, and I came through in the under stove location - where the pressure pump and hot water heater are located. It was an easy pass through to the inverter/charger location. Jim
Old 05-18-2023, 06:03 PM   #23
Usually you can park close enough to the power pedestal that a short cable will reach. I got a 6' cable to put through the hole. A plus is you can keep a portable surge protector inside the locked compartment, in line between the short cable and the Roadtrek cable.
Old 06-03-2023, 01:49 AM   #24
Bob, how did it go. Good I hope.
Old 06-03-2023, 02:59 PM   #25
Deano, I chickened out on how you did yours (for now). Here's what I did. So far it is working. This was someone else's idea-not mine.
2005 Roadtrek 05C210v
2020 Can Am Spyder RT Limited
Bangorbob is offline   Reply With Quote
Old 06-03-2023, 11:21 PM   #26
Looks good to me and was a safer place to put it as well.
Is that the piece we discussed that came loose? Having it anchored adequately would be my only concern, As I recall, you already did.
Old 06-03-2023, 11:25 PM   #27
Yes, that is the corner cover that came loose. I use expoxy on the strap that attaches to that piece and then I run a screw thru the whole thing. It's pretty strong but not a strong as the side of an RV.
electrical problem
