Originally Posted by avanti
First light!
Alternator came up without issues. Battery was full so I couldn't look at charging behavior yet. But, I did do one test: Turned on the inverter and the Air Conditioner. The Trimetric showed -132 amps. Started the engine. Trimetric immediately went to +1 amp (on idle). I'm liking this.
I am now running the A/C to get the battery down. Then we can get a look at charging.
Sounds nice!
132 amps at idle is really good for 200 amp alternator. Was the engine still on fast idle at the time? The probably also spin the alternator a bit faster than usual when they use it as an add on, besides. Do you have a tach so you can measure alternator speed?
