Gentlemen,
Based on the OP's original questions, what would you recommend if at this stage she is set on keeping the Generator* versus something like an upgraded Alternator or a Dual Alternator system**?
*not stealthy at all
*not stealthy
Add some Solar but its Winter mostly?
2 x 6 volt Lifeline AGMs, 225ah Total
Or 2 x 12 volt Lifeline AGMs, 200ah Total
And putting the batteries under the bed, reconfiguring the battery set up?
Or leave them out in the Cold & Elements?
CORRECTION;
When I stated "I can see problems immediately..."
I wasn't talking about any present issue but the fact in the past, having all the wiring on the outside of the Coach made it visually difficult to see any issues & even if I master all the equipment I have to check electrical performance, where the actual issue is, requires a lot of painstaking examination - much easier when everything is INSIDE the truck.
