12-02-2018, 10:19 PM
Fire extinguishers.
I am selecting fire extinguisher, my old Halon one has low pressure and is too big, so I want to get a new one and mount it at the sliding door under the potoman . The easiest mount to attach to the 8020 aluminum framing will be this https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER.
I selected either this small 1.4 lbs https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER or a larger one 2.5 lbs will fit under the place under the cassette toilet. Amerex Halguard has small and large unit at similar prices.
Comments are welcome.
12-03-2018, 01:18 AM
Just a personal bias but I prefer Halon 1211 which is still available. It saved my butt last year and I was able to get it refilled. I just bought three new 1211 extinguishers. Can't remember from whom but I bet Amerex has them.
12-03-2018, 01:33 AM
Can you educate on the advantages of Halon extinguishers. All I have are the old style dry chemical ones.
12-03-2018, 01:41 AM
Fire off a dry chemical extinguisher and you are left with an extreme corrosive mess to clean up ASAP. I don't know if the Halon substitute extinguishers work as well as Halon 1211 but I know Halon 1211 works very, very well so I stick with it.
12-03-2018, 09:01 PM
New type of fire extinguisher, many benefits. Only downside is not refillable because once activated, it runs till it is out.
https://elementfire.com
Joe
12-03-2018, 10:09 PM
It is interesting product made in Italy, see the link, it leaves some residue of potassium salt. Potassium nitrate with some other chemical is used to produce and propel the flame suppressant. It is warrantied for 3 years only. Sicurezza
I will go with either Halon or Halon replacements such as Halotron or Haliguard. CO2 extinguishers are also good but too big. Amerex used to sold 2.5 lbs. unit but it is no longer available.
As I was looking for fire extinguishers a few minutes ago I smelled something burning like cables, insulation, something electrical. My first thought was – did Google marketing is going so far to discharge smoke to keep me looking? Checked PC, power supplies, smell was only in this room not outside or the rest of the house. Finely eureka, it was the small fluorescent bulb in the ceiling fixture.
12-03-2018, 11:25 PM
If you want a traditional style fire extinguisher with HalGuard, try Bruce's Speed Shop. Great prices
Bruces Online Speed Shop - H3R Performance
Joe
12-03-2018, 11:43 PM
Thank you, indeed good prices.
12-05-2018, 11:29 PM
I ran across this option. I Don't know anything about it other than it is expensive
https://www.ake.com/about-us/
12-06-2018, 12:59 AM
Interesting fire extinguishers, expensive.
I decided to go with the Amerex Halotron 2.5 lbs. from this place https://fireextinguisherdepot.com/fi...ting-2b-c.html
The flat mount is from this place https://tek208.com/product/quick-rel...black-anodized I was looking for a mount allowing removal with one hand due to placement, just above the lower step at the sliding door, and this one should work.
My second choice was a Halon extinguisher but price skewed me towards Halotron and halon is getting outlawed in some states for personal use, you can still get them even though manufacturing stopped almost 25 years ago. I have an old Halon extinguisher but would need to be tested, it is really in bad shape, at least it looks bad.
12-06-2018, 01:50 AM
George, what aren't you prepared for?
12-06-2018, 02:19 AM
I wish to know.
12-06-2018, 12:21 PM
Have you received yours? I'd like to order one, as well, but am unfamiliar with the company so wanted to be sure they were responsive.
2018 Coachmen Crossfit/Beyond
12-06-2018, 05:14 PM
I ordered both 2 days ago, the mounting bracket via Amazon will be delivered on Monday.
The extinguisher will be shipped directly from the Amerex Co. I ordered the extinguisher with chrome finish which is custom and it will take 2-3 weeks to get it. I talked to them before ordering.
We discussed which color and decided on either black, white or chrome, red would be to pronounced in this very visible place so chrome with 2-3 weeks delay was OK.
12-07-2018, 05:03 PM
The engineering marvel came in, impressive quality. It is expensive but during fire emergency I would pay tenfold for quick, single handed extinguisher removal.
01-03-2019, 02:57 AM
Fire extinguisher installed
Installation of the fire extinguisher finished, easily accessible at the sliding door, one hand removal.
09-22-2019, 10:38 PM
George,
I am considering upgrading the fire suppression in our rv's. Now that you have had your system in place for several months and hopefully have not had to use it, are you still happy with it or would you now use something different?
Almost pushed the submit button to order but thought that I would check for your possible update.
Thanks,
Pat
09-23-2019, 12:24 AM
Having nearly lost my Roadtrek 190P to fire I have a little different take.
Halon worked so very well for me so I will have no other.
Instant access is the most important. I have one mounted by the bed in the back and one on the wall above my head in the driver’s seat.
Placing one behind a sliding door is a non starter for me unless it is the third one.
When I lit off a propane leak from a loose fitting behind the fridge I was outside beside the fridge. I ran to the back, turned off the propane, opened the door, grabbed the extinguisher ran forward and squirted through the fridge vent. Fire went out.
The lesson was the extinguisher had been floating around in the bedding for years and I had to search for it. It needs to be hard mounted so you know exactly where it is in the dark. I was stupid to put myself in that situation and lucky to have the extinguisher and be able to put my hands on it in the dark.
With an engine fire you want to Be able to grab it from the driver’s seat. You are also in the perfect position to help someone else.
When I took it to be refilled they laughed at the little 1 1/2 lb bottle. Said it was useless. I used 16 ounces out of 24. Saved my van.
09-23-2019, 05:42 AM
Originally Posted by MobileCabin
George,
Thanks,
Pat
I would repeat the same, Halotron is much less damaging to ozone layer than Halon and a reasonable substitute. Halon is no longer available on open market but still available for airplanes.
I like the bracket a lot, single push on the lever to remove the extinguisher.
