Old 03-27-2015, 07:26 PM   #41
Default Re: Mojovan progress
Installed Brake control, wired up the aux led backup lights, backup buzzer, added back up sensors, added extra ground wire since I will be drawing more amps when I install the battery to battery chargers. Tied to back up light feed to operate relay. Floor mat is finished, 1 3/8" gym rubber with carpet raises the floor back to the pre swivel height and feels great on the feet. Adds sound proofing and insulation. Have a weather tech mat to go over that.
http://s1276.photobucket.com/user/mcgio ... ovan/story
Old 03-27-2015, 08:57 PM   #42
Nice spot for the brake controller. The mat looks good too.
Old 03-27-2015, 10:54 PM   #43
Thanks, just test drove it, the thick mat puts my foot in a more comfortable position in relation to the pedals. The $15 amazon back up sensors work great. I had to muffle the back up buzzer, it was way too loud.
Old 04-02-2015, 08:05 PM   #44
Just finished the solar panel cover, made from heavy Sunbrella, I picked the color closest to the dirt,bird droppings etc… that have been accuminating on the top of my van. The cover slips over the front nose and over the edges, held on by velcro straps. Didn't design it to travel with it on but it looks like it would stay on the road. I'll have to test it.
Old 05-26-2015, 03:48 PM   #45
I am currently in Edinburgh, getting close to the end of our two months of travel, there sure are a lot of nice vans here on this side of the pond.
Old 06-08-2015, 06:50 PM   #46
Default Webasto air top install
Had to finalize and install Webasto gasoline heater before the floor goes in. Not easy to find a spot in my layout. You will need cut away any existing flooring and find a spot with clear access underneath. I squeaked in to this spot. Behind the drivers seat. That is a 1/4" steel flange I made to compensate for the ridges in the floor. The mounting studs on the heater are only an inch long so finding a flat spot is ideal.
http://s1276.photobucket.com/user/mc.../Mojovan/story
Old 06-08-2015, 11:13 PM   #47
Hope your trip was great & it\'s good to see you back on the project!
Old 06-10-2015, 01:49 PM   #48
Boxster1971's Avatar
Nice work. What is the purpose of fabric covers over the solar panels?
Old 06-13-2015, 02:07 AM   #49
Keep sap and bird crap off when idle. I'm running Lithium batteries so a float charge is not needed. Ideal long term storage of these batteries is 50%.
Old 06-20-2015, 11:06 PM   #50
Installed floor insulation/soundproofing. Each section has MLV sandwiched between closed cell rubber. Frame work installed with doubled sided foam tape and a few screws. I'll be putting 1/2" Ply on top.
Old 06-21-2015, 01:32 AM   #51
That last link didn't work for me but this one should: http://s1276.photobucket.com/user/mc.../Mojovan/story
Old 06-29-2015, 03:16 PM   #52
Underfloor storage compartment framework, added LEDs, Floor is raised to compensate for elevated benches/bed. 8 1/2" x 55".
Old 07-03-2015, 10:59 PM   #53
WIFI and Cell booster antennas mounted.
Old 07-03-2015, 11:19 PM   #54
What are you using for a cell booster?
Old 07-03-2015, 11:37 PM   #55
Haven't bought one yet, figure I'll get a wilson unit when I figure out which one to get. Needed to get all the antennas in so I can button up the roof and start on the ceiling.
Old 07-05-2015, 09:25 PM   #56
Default Solar panel side covers
Didn't like the side of the solar panels visible, made these covers, first one up. Looks a little bit cleaner now.
Old 07-13-2015, 10:08 PM   #57
Areogel insulation installation. Hard to cut due to reinforcement fibers in it. Very dusty unless you hit it with a leaf blower before handling. Tested with laser thermometer inside. uninsulated 107F, Reflex only 96F, Reflelex and Aerogel 81F or ambient temp.
Old 07-28-2015, 08:47 PM   #58
Ceiling installed, 1/4"ply. 1/8" rubber foam. marine vinyl, led lights.
Mojovan Story by mcgiotes | Photobucket
Old 07-28-2015, 09:31 PM   #59
Nice looking work mojo! I always thought these sliding cargo doors eat up too much needed inside space, too much trouble to open and close all the time and would be a pain in the butt most times. Not just Promaster, but all of them. I would like to see someone weld that cargo door shut and have a removable passenger seat, kinda like a class A pusher entry. Maybe a small bench seat for driver and passenger and no bucket seat for passenger. Looks like you have that ability to come up with something. Or...leave it all alone! Like I said before, quality work! Thanks for sharing.
Old 07-28-2015, 10:54 PM   #60
There's an outfit in Australia that fabs fiberglass panels to replace the slider to a regular camper door. Shipping costs are prohibitive though.
