Old 05-02-2016, 12:28 AM   #21
My PWM controller only displays voltage, ah, and total amps (for the day I'm assuming). While it was showing 14.5 ah, it was also showing 13.6 volts.
I guess I don't understand what the controller is saying. Voltage is obvious, amp hours is probably for the day or maybe total since reset, but I don't know what total amps could be as amps are an instantaneous reading, not a total of anything. Are you sure you don't have total amp hours and daily amp hours? Or maybe amps to go with the volts?
Old 05-02-2016, 12:39 AM   #22
wincrasher's Avatar
I probably am confusing my terms - it's been avery long day.
This is the controller I have - http://zampsolar.com/newsite/wp-cont...web-upload.pdf
It gives voltage, charging current and charging capacity (ah). The current was reading 14.5. The capacity had a pretty high value as it was around mid-day, but I don't recall what it said.
But looking for the link above, I see they now have a lithium specific charger, so I'm probably going to go ahead and order that.
Lithium Ready Dual Battery Charging 30 Amp Solar Charge Controller - ZS-30AD - Zamp Solar
2019 Winnebago Travato GL
