Old 11-23-2015, 02:04 AM   #1
Default 96 rialta 2.5 5 cyl gas engine runs bad cold
engine idle rough 7 miss will not take gas right no power for about 2 minutes then runs pretty good cleaned throdle body 7 iad any info will help thanks
Budd y is offline   Reply With Quote
Old 11-23-2015, 10:26 AM   #2
bigdan's Avatar
could be :
your IAT ( intake air temp sensor )
coolant sensor
cold start injector at the intake end ( driver side )
1) verify if you have any voltage at cold injector when cold ( before starting engine but ign "ON")
if so , start engine disconnect it : same or worse
if worse,reconnect, if same could be it …..
next :
disconnect coolant sensor
same or worse ,if worse
reconnect if same could be it ,
disconnect IAT ( intake air temp )
if worse , reconnect …..
Dan
