Old 06-21-2012, 09:13 AM   #1
Default Tank Status Display Panel Problem
Our 2002 Rialta HD tank status display does not work: the small buttons that display tank and battery status display no status indicator lights when pressed. The switches for the generator and shower pump do work.
We contacted a Winnebago sales and repair facility here in South Carolina: the unit is no longer manufactured. Replacement would require "replacing our tanks."
Are there replacements that any owners know of for this electronic unit, or its circuit board?
Best regards,
Bill & Paulette Blask
Bblask75 is offline   Reply With Quote
Old 06-21-2012, 06:52 PM   #2
rem
Try this site.
Mobility RV Inc.
818 Hwy 9 East
PO BOx 85
Hanlontown, IA, 50444
(800) 933-7742
http://www.winnebagoparts.com
rem is offline   Reply With Quote
Old 07-04-2012, 07:06 PM   #3
Thanks, Rem, for this information. We've contacted them.
Best regards,
Old 07-04-2012, 07:12 PM   #4
rem
You are very welcome, hope you can get the parts.
Rem
Old 07-05-2012, 09:36 PM   #5
Winniebagoparts.com told me they did not have the monitor panel for an '01.
Let us know if they have one for you.
gene
Gene is offline   Reply With Quote
Old 07-06-2012, 11:10 PM   #6
Gene,
They responded in the negative, suggesting I look for aftermarket substitutes. I'll post something if I am successful. It was worth a try!
Bill & Paulette
Old 07-07-2012, 08:13 AM   #7
I am also looking and will let you know if I meet success.
Gene
Old 07-28-2013, 09:57 PM   #8
I also have a 2002 HD.
Here is the info I got from Ventline the manufacurer of the monitor panel:
"The LA1023-00 monitor panel is no longer available as we can’t get the circuit
board anymore (another supplier that went under because of the economy in
early 2009). I am suggesting that customers use the LA1046-00 panel – it’s
bigger so that may be a problem if the coach has cabinetry in the area.
Unfortunately this isn’t a plug and play – wires will have to be connected
individually. There will be some extra wires that will be left loose (the LA1046 has
a water heater switch while the LA1023 does not). The generator switch and
wires from the LA1023 panel will need to be removed and installed into the
LA1046. There is no indicator light for the generator on the new panel so that will
be another wire that is not connected.
Our engineering manager said most of the wires are color coded the same but
you might still want to label them with the pin location number prior to snipping off
any connector. The labels may help when comparing to the drawings.
LA1046-00 MPW,2T,FW,B,LP,WH,WP $105.63
You may order directly from us by calling (574) 848-4491 x215 (Heidi) or x213 (Marty) or x234 (Jill). They’ll be able to assist you with freight charges, etc.
Sincerely,
Suz-anne Ritter| Pricing Administrator
Ventline By Dexter – Dexter Door
902 S. Division St. | Bristol, Indiana 46507, USA
sritter@dexteraxle.com | direct tel: (574) 848-4491 x229
fax: (574) 848-4825 | main tel: (574) 848-4491
Dexter Axle ~ Dexter Door ~ Ventline"
michaelmiracle is offline   Reply With Quote
Old 07-29-2013, 12:24 PM   #9
mloganusda's Avatar
What most Rialta owners do is look under the rear passenger seat to see how much water is in the tank. The black water tank we just look down the open toilet with a light to see how much space is left before full. The gray water tank can be looked at if the bottom drawer is removed but when the sink will not drain or fills up you are full. Time to dump when you see the tank is full.
Old 07-29-2013, 10:13 PM   #10
sie
Hi Bill,
mine had the same issues...i fixed mine, after opening up the pannel, remove four screws...10 minutes max... i offer to walk you through it over the phone step by step...
i would not have offered , but saw your mention of the generator and shower switching working...when they do not work as well my fix will not work....no promise this will be ten minutes is a small time investement....
i like my systems to work...but the other methods of checking levels work as well... except propane level...
reply directly to me with a phone number and time to call... my email, hdbaggerman@gmail.com
all the best...! ! !
richard aka sie
lake texoma, texas shore
sie is offline   Reply With Quote
Old 10-31-2015, 08:56 PM   #11
Hello All,
I know this post is a little old but I have the unfortunate task of letting you know that Richard aka Sie (posted above) has passed away. Please do not contact that e-mail for advice.
I have taken apart my panel and if my repairs works, I will post pictures and a quick "how-to" that may help otheres out.
Again, our best goes to Richard's family.
Respectfully,
Sam
saminole is offline   Reply With Quote
Old 11-01-2015, 10:05 AM   #12
bigdan's Avatar
thanks Sam ,
Always sad to hear that a member has passed away ....hope he dint suffer too much
Ill wait for the pics ,because i have that problem too
Dan
1996 C-21 Triple E ..... 86 Jeep CJ quite modded , 84 olds cutlass resto mod ,
On or off road , I`m on the road ! roadtrips !
bigdan is offline   Reply With Quote
