08-07-2015, 02:48 AM
#61
Why did you remove the stripper poles?
10-07-2015, 10:15 PM
#63
Few more things done
Aux battery mounted, to be used when main lithium unit is not needed, bathroom walls in. Calculated interior of bathroom by sitting on toilet, measuring how far my knees and feet protrude for depth, and for width, included elbow and arm swing needed for the "paper work". Lower raised area will contain Aux battery,heater, sterling battery to battery charger, aux battery controller, battery cutout switch, trickle charger and what ever other electrical stuff I can fit into the area.
Mojovan Story by mcgiotes | Photobucket
10-08-2015, 03:21 PM
#64
Lot's of progress - I hadn't checked recently.
This link might show the newer photos: mcgiotes's Recent Uploads | Photobucket
10-12-2015, 06:10 AM
#65
Many people think they need a door to the restroom.Consider a drape instead.Lighter and flexible.
10-12-2015, 01:11 PM
#66
Yes, that was my first thought until the wife demanded a door.
10-23-2015, 09:59 PM
#67
Little more headway, built a cabinet around the fridge 7 CF marine unit 12v and 110 with the ventilation ducted over the top. It is removable as a unit so any problems down the road I can remove the whole cabinet and fridge. Front step area almost done and will house allot of electrical stuff and the heater.
10-25-2015, 08:01 PM
#68
Nice looking fridge!
Van Williams
CargoVanConversion.com
11-12-2015, 08:47 PM
#69
Bamboo countertop
11-26-2015, 02:05 PM
#70
Yes. A very nice fridge. Can you tell us where you bought it? I think you mentioned getting it in Florida.
11-26-2015, 02:16 PM
#71
Wow, it's really coming together. Really like the scheme you are going with - dark cabinets, light/white flooring and stainless appliances. Really pops!
That fridge is tremendous. Looks to be this one? http://www.defender.com/product.jsp?...6235&id=922260
11-27-2015, 08:05 PM
#72
Yup, that's the one, that's why I installed a dedicated surge protector to it. Its the most I every paid for a fridge in my house! It uses very little power to operate and very quiet.
12-28-2015, 10:00 PM
#74
Solid woodwork! Where did you get these cabinet locks?
Van Williams
12-28-2015, 10:48 PM
#75
Van Williams
Southco M1 or similar. Sportsmobile uses these on almost all of their builds.
M1 - Flush Pull Latches - Southco
12-28-2015, 11:00 PM
#76
Amazon had them for a while.
12-28-2015, 11:16 PM
#77
It's time for me to start thinking about latches and other hardware. These seem quite solid and look attractive.
Van Williams
01-03-2016, 11:41 PM
#78
One more cabinet
Weather gauges,heater control, battery charge controller, led lights. First attempt at caning/wicker.
02-02-2016, 09:23 PM
#79
Started power section
Started on the lithium battery pack, inverter section. Its designed to so I can service anything in place. A plate slides over the battery section and the Magnum 2812 bolts to the plate. Most of the controls and power panel will be mounted to the door/access and hinged for ease of access. (20) 180amp lithium cells, 400amp fuse, inverter/charger controller shunt, Contactor, dual pole battery switch. The buss bars were made with my VCM, "vice,cresent wrench & mallet"
The pack will have 4 ways of charging, solar,alternator,shore or generator.
02-13-2016, 04:13 PM
#80
Power center
Almost done, it will be easy to access for service. the entire center will weigh in at about 350lbs including the batteries and the really heavy inverter.
