10-04-2023, 04:25 PM
Update on our lithium "test" bank in 07 Roadtrek 190P
I have mentioned a couple of times that I decided to do a test installation of three SOK, 206ah, 12v, "drop in" style batteries.
Having mentioned many times in the past that I felt the whole idea of "drop in" lithium swaps was not a great idea because of the differences in care and feeding that lithium require, and I still feel that way. I have watched the lithium market for a long time for pricing, features, claims (outrageous and some believeable ), etc and a few recent things made me decide it might be a feasible for our particular system because of it's programmability.
The things that have changed in the marketplace to convince me.
* Much lower pricing on lithium
* The availability of a removable cover, serviceable, drop in battery
* Ability to monitor individual cell voltages on all cells
* Improved amp hour capacity per footprint space and volume
* Class A cells being offered
* Some changes in specifications and parameters from manufacturers but all are still contradictory and only address some of what "best practices" appear to be.
* The availability of a much better alternator remote regulator that can terminate charge based on shunt measured amps to the batteries.
We had two trips planned for this summer, our yearly spring 16 days to Custer State Park in SD, and a one month long touring type trip with 2-5 day stays along the way going to the U.P. in Michigan, western New York to visit a fellow member, and then the Skyine, Blue Ridge, Smoky parkways and our final stay in Smoky Mtn NP.
We simulated how we intended to test the lithium bank on our trip to Custer, but with our 440ah of AGM batteries. We never used shore power and had the solar shut off. This gave us a comparison of what SOC the AGMs would settle at with less than the very long charge time it takes to get to 100%. As expected, they ran in the 40-85% range on that trip except for the long ride home where they got nearly to 100%.
I put the lithium in with temporary wiring when we got home and got what I felt were safe parameters. I programmed the shore charger and solar controller for them, but we did not intend to use either unless we had to. The Ample Power remote regulator on the parallel alternators was changed to a profile that was closest to decent for lithium, on the safe side and I shut off the charging by just disconnecting them from the alternators based on an ammeter on the dash.
The batteries were not very good out of the box and required a bunch of work at install, which the next post will go over. Long story short is that if they could not have the covers removed, they would not have worked adequately, IMO.
10-06-2023, 11:31 PM
I will go over what I found in trying and testing the batteries at final install. Lots of detail will not be there and if interested just PM me or ask here.
Batteries are 3 X SOK 206ah 12v lithium batteries with claimed grade A cells and removable covers for servicing if needed. They are replacing 440ah of Lifeline AGM 6v GC batteries.
Instructions for the batteries said to charge each of the batteries individually to 14.4-14.6v to get them even in SOC before installation and charging/discharging as a group in parallel.
First issue showed up immediately as none of the batteries would go past 13.8v without tripping the internal high voltage trip out. I later figured out this was because of poor cell to cell balance and the trip out looks at the individual cell voltages so if one is high it trips out early.
SOK said to just leave it at 14.4v and let it cycle up and down until the internal balancer fixed the balance, but the trip kicks out the smart charger so it is not ready to charge again when the voltage finally goes down. After half a dozen manual restarts and nearly no improvement I decided to order a 10amp regulated power supply to do the initial charge. They are under $50 on Amazon and other places. Using it the cycling would continue on it's own, but after 48 hours they would barely charge to a higher voltage overall and I decided I couldn't wait a month to get them all balanced. I removed the covers and balanced the individual cells with power supply to 14.4v and 3 amps current. Put them back together and all of them would go to 14.4v without tripping so I let it run until the Bluetooth showed very good cell to cell balance.
I put them in the van and did a discharge test where it ran all the accessories just fine, but the batteries show huge differential between discharge currents of 50% or more which caused the batteries to trip out early. Recharged and saw the same variations. SOK did not offer any useful help so I started looking for resistance variations between the batteries and found none, cable lengths balanced etc.
I then removed all 3 batteries and opened them up, and moved the BMS and cover from the slowest battery to the fastest one and vice versa. The problem moved with the BMS. SOK wouldn't send new BMS to try without sending in the whole battery at my cost, so I did a bit more checking for resistance and found the wire connection from the cells/BMS to the cover connecting point showed high resistance. I took it apart, cleaned it all and put it together and reran the tests.
I had received two batteries with much lower serial numbers than the third one and the newer one was working much better for charge and recharge rate than the other two, although the really low one was good now with the wiring cleaning. I opened them again and noticed the two lower serial number batteries had the BMS/balancing wires (4) placed under the buss bars and wiring while the higher serial number had them on top like I now know is how they should be. I moved the wires on the two batteries and retested them.
Charge and discharge rates were now very close to equal between all three batteries and they charged well and capacity tested very good.
After a few cycles the balance of them got even better to nearly perfect and stayed there even if I changed to lower than the balancer activation voltage of 14.4 to 14.6v as I consider that too high for long battery life.
I finished up the rest of the install to get ready for a 30 day shake down trip that would be done with only alternator charging with the best settings I could get with the Charles/Ample Power regulator at 13.8v but not very stable.
The batteries performed very well on the test trip and actually exceeded expectations. The trip also let me test controlling charge termination by using amps instead of volts alone and I found it was much more consistent that way.
The next post will summarize how I tested and what the results were.
10-07-2023, 12:29 AM
Good reading. I'm enjoying all of your posts/info. Thanks for taking the time to keep us all informed.
10-07-2023, 06:36 PM
Are you planning to use shore and solar charging sources. Are your solar charge controller and shore power charger programmable for Lithium profile?
10-07-2023, 07:55 PM
I think both of those items may qualify for the "yet to be determined" category, but we really enjoyed the no plug in, no wet dirty cord, routine on the test trip which was intended to test only alternator charging.
If I had to guess right now, shore power will probably not be used at all unless we absolutely need air conditioning.
Solar is a bit tougher as it does not have a "lithium" setting, but IMO the lithium settings are generally not what I want anyway. It appears that the newer versions of our Blue Sky controller have a two stage setting which would work well and even if we have to use 3 stage we would only use it if we we want to be offgrid without driving for about a week. Our controller rebulks at the float voltage so pretty much a two stage anyway.
We were totally amazed with how much more convenient it is to not plug in, not from the plug in necessarily, but from the putting away a cold, still, dirty cord early in the morning when it is cold and dark.
I am finding this whole adventure very interesting and educational, plus it looks like we may actually come out of it all with a quite functional system.
l will point out, and probably repeat many times, that our charging equipment is very much more flexible than most systems in class b's so our experience will likely not be able to just repeat for anyone else. It is very obvious to me that the lithium batteries we got are far from being true "drop in" to a lead acid system.
10-07-2023, 08:07 PM
Seems like SOK's assembly process has room for improvement. The issues you've discovered are pretty fundamental to building a lithium battery.
I appreciate your willingness to write up what you've experienced - it'll no doubt help someone someday.
10-07-2023, 08:37 PM
I completely agree on your assessment, although for me it was not unexpected. I have read about numerous lithium drop ins of various brands tripping out early so kind of expected it. I probably would not even gone on this adventure if I couldn't get the batteries open to be able to address the predictable problems.
My guess is that very few of the manufacturers top balance the cells the put in their batteries and that causes the issues I, and others, have seen.
When you only have a couple of tenths of a volt between the charge voltage and full shutoff of the battery, there is very little room for inbalance.
10-08-2023, 09:03 AM
Thank you for your update. It helped me to decide staying with Fullriver AGMs. My 2013 system is designed for low attention required with AGMs. All 3 charging sources don’t have Li profiles (whatever the lithium profile is).
For alternator charging I would need to change from ME-SBC to something else. ME-SBC has voltage adjustment but likely not accurate enough. Charge termination would need to be manual.
For solar charging my Mornigstar TS-MPPT 45 has fixed voltage option but charge termination would need to be manual.
For shore charging my Magnum MMS1012 inverter/charger has custom voltage setup available but again termination of charge would need to be manual.
I could go with Lithium by completely replacing all 3 charge controllers, this would be a big project, too big for my 2013 campervan.
With my current charging system the decision would have two main factors:
Lithium advantages over AGMs (weight, capacity)
vs
practically automatic operation of my current AGM system.
10-08-2023, 09:52 AM
vs
Can't disagree with any of this if you are happy with your current setup.
You charging of AGM is not the best using voltage and time like your sources are, so you get a bit shorter life, probably, but at much lower upfront cost than it would be to go to tail amp charging on them all. Our AGM system already was using tail amp charging so a no brainer for me to try to use it on lithium, and it does appear to work quite a bit better than voltage and time for them also.
10-08-2023, 03:03 PM
... so I did a bit more checking for resistance and found the wire connection from the cells/BMS to the cover connecting point showed high resistance. I took it apart, cleaned it all and put it together and reran the tests.
I opened them again and noticed the two lower serial number batteries had the BMS/balancing wires (4) placed under the buss bars ...
I also learned (from experience) that low resistance, high-current charge/discharge setups are far less tolerant of marginal wiring, buss bars, etc. My current setup can charge at up to 95A, making the quality & cleanliness of crimps, wiring and connectors, as well as proper wire selection much more relevant.
Seems as though some LiFePo4 vendors are still on that learning curve.
10-08-2023, 04:11 PM
Yep, I think the lower serial number ones where during pandemic, so probably not as well controlled.
Everything does have to be just right, cable lengths, connections, even the bolt lengths into the batteries and to the cells inside them. There are two different lengths used at the cells depending on how much stuff is connected to them.
We have the capability to charge at near 300 amps in the system, but these batteries want a relatively low charge rate of 40-50 amps per battery, with the 40 preferred, so we will setup for probably 120-125 amps. That is where it was during the testing also and worked well.
The lithium manufacturers are quickly going to much lower charge rates recently and some data is starting to show that a .2C charge rate is the highest you can go before you start to get shortened life. This is the a huge change from the original claims from a few years ago of 1-3C being just fine for LiFePO4 batteries.
10-08-2023, 07:14 PM
Tail amp termination would have to manual, hence headache, monitoring voltage instead of camping.
10-08-2023, 07:47 PM
The test trip was planned for a while as just another trip, but after testing the no shore power pattern with the AGM batteries while at Custer this spring it dawned on me that the fall trip would be a perfect test trip for the a test lithium bank to sink or swim. Otherwise the test lithium install probably would have been this winter.
The trip was 30 days long with 9 stays at different places along the approximately 3700 mile route. Stay times varied from 1 night to 5 nights with most at 3 nights. The intent was to leave the solar panels off and never use shore power to test the major anticipated power source, alternator charging, in the real world. Drive days were in the 4-5 hour range most times, which would have been about 1/2 the time it would take to recover the AGM batteries if they were used. The intent was not to intentionally restrict power use at all (hard habit to break ). It included uses the microwave multiple times a day, an Instant pot probably a dozen times, furnace at night, fans as needed, recharging the laptop a couple of times a day sometimes, TV and videos, etc.
We wanted to see how fast a 120 amp setting got the batteries to our chosen full setting, which was intended to be 90-95% of capacity.
I also needed to try to determine the best way to hit the 90-95% full consistently. My guess was to use the amps to determine the shut off point, but didn't know what number to use. I started at 10 amps but had quickly saw I needed to go higher as the batteries got too full. Ended at 50--60 amps which appeared to be closer to what we want.
Because we wouldn't be charging at the autobalancing minimum voltage trigger point voltage, I needed to see how far the individual cells would go out of balance in real world use and at various discharge rates and depths.
Also the other normal stuff known to happen with lithium like unexpected shutdowns, temps during charging and discharging ect.
The hardest part of the test was trying to catch the amps at the right place during charging while driving. Started at 13.8v and 120 amps but once the amps started to taper and got below about 80 amps they fell very quickly. We were on a lot of twisty, hilly, high traffic, roads so hard to watch that close.
The results were substantially better than I had anticipated as everything worked well for us.
* Never had to plug in or use solar, and routinely wouldn't even charge on every driving trip.
* The highest amount of recharge was a bit over 300ah and that was on the first day as I had intentionally discharged the batteries that far to see how they charged right away on the trip. The rest of the charges were in under 300 and over 150ah depending on how long we stayed places. We returned home after 6 nights without charging and at the same SOC as we left home at.
* Charging went well and usually was done in 2-3.5 hours.
* The batteries ran all our uses without issue.
* Cell to cell balance stayed extremely good over all the charges and discharges and never more than .003v and we returned home at .002v range which is what they were when we left home 30 days previously.
* Battery temps were rarely even 5* above ambient in the van.
* No shutdowns or other weirdnesses.
* The Ample Power/Charles alternator regulator had trouble controlling the voltage and amps consistently because of the way it caps output which is by putting a hard cap on field %, but that was expected and it will be replaced with a Wakespeed going forward.
* All in all for a first test it went amazingly well and gave no reason to put the AGMs back in and abandon the lithium switch.
* Not having to deal with cold, stiff, wet, dirty power cords in the morning when moving on was a highlight for us.
I think that without all the pretrip testing, balancing and getting all the charging and discharging stuff evened out, the testing on the trip would have been pretty ugly. The batteries probably would have supplied enough power and charged enough to recover it, so without a look at what was really going on a user would never know they probably were headed for future early lost capacity on the bank. I have no idea if other brands of batteries would have issues or not, but the guess is that at least some will and testing is the only way to catch it early and fix it.
The next post will be to explain what the system will be going to now that we know we want to keep the lithium and need to do the final changes and wiring cleanup. The only major change will be the voltage regulator swap, I think, and a lot of other cleanup/fix up stuff, and lots of final settings.
It has been an enlightening and very interesting project to this point, and I am finally getting a chance to lithium, both the good and the bad, for myself, closeup, and how to make it work the way I think it should. Very educational for me, and that was one of the major reasons to do it all.
10-09-2023, 04:12 PM
The batteries were installed in the quickest and easiest ways I could come up with due to time constraints to have it ready to go on time, with a least some preliminary testing done. Wiring cleanup and improvements are a big part of the need and the install of a Wakespeed alternator regulator and it's programming will be most of the work.
The 3 new batteries sit behind the driver side rear bed bolster and right along the rear wheelwell. The AGM bank was hung underneath the van where the generator used to be and the charging equipment and controls are on the passenger side, so pretty spread out locations. To make it quick and easy, I just ran two cables from the new lithium to the left rear corner of the storage area under the bed, and put them through the floor there and back over to the connections that were for the AGMs. The rest of the cables stayed in place. Lots of extra cable though and voltage drop in it all.
We have a full time bed in the back so I will be able to go right straight across the bottom of the bed by mounting an aluminum channel to the fabricated bed frame to use for a cable raceway and support. That should turn two 15+ foot cables into two 6 foot ones and eliminate some connections. The alternator line which is at same underbody connection point will be made to come up into the battery area directly as that is about where it comes to the rear now before going across to the old battery location. It will connect directly to the batteries with a fuse.
I already had a 300 amp inductive shunt in the rear that went to the front ammeter so that wiring will be run to the main shunt in the right side electronics area. It will add the ammeter and the Wakespeed shunt input to the shunt which currently runs the solar and shore charge control.
The Wakespeed regulator will go under the passenger seat where the Ample Power one is now and use some of the same wiring. I will have to add some wiring to tie in the shunt and put in one for the alternator temp sensor, but a lot will stay the same and get cleaned up. Some control switches used to the Ample power will be repurposed to match what I will want with Wakespeed but stay on the dash in the same place. Mostly putzy and hard to get at it all under the dash and seat.
Programming the Wakespeed looks to be done with an App for the laptop/PC and transferred into the Wakespeed by a USB connection. They talk about having over 100 possible settings so might be a handful to understand at first. The is also a phone app that can be used for lesser changes and monitoring.
There is very little information around on the Wakespeed except for some Youtube videos and those are always suspect. Wakespeed does have generic and brand specific profiles for lots of batteries but they are not the specs I want to use so will be into the custom programming of that part.
I will also add active balancers to batteries as my charge voltage won't activate the SOK passive ones. They will be on a manual switch and not used unless needed and then turned back off. A Sterling Alternator Protection Device will be put on the separator input and should be able to handle both alternators, mostly because there is also the starter battery in the circuit and van running loads.
Next post will go over the charging specs I will use and my reasons for choosing what I did. They are truly arbitrary and not what most of the drop in battery people, including SOK, recommend, but their recommendations make no sense to me at all unless they are heavily marketing based so make selling them easier to the public.
10-10-2023, 12:53 AM
booster - did you remove the AGMs - or, it sounds, maybe just disconnected them? Is the plan to re-use that real estate and recoup space under the berth for the lithium batteries - or repurpose for other options under chassis?
[I'm happy with my bank under chassis, but I note yours includes internal heaters. Good feature. Are the cases IP64+?]
Just curious about the full conversion steps you plan next with the LiFePo4 for your van. I note the Sterling alternator protection thinking.
I note you mention 2.5-3 hours on recharge. What was the level of discharge? You said 120 Amp charge - is that a limit of your alternator/Ample Power setup? I like your testing of "no-limits" to use, but seems a similar recharge profile could be warranted too. The 120 seems overly restrictive, unless the test was to check the "bottom end." Or, is it a function of the Wakespeed controlling how much the alternator provides? It is alternator temperature limited, right?
Cheers - Jim
10-10-2023, 01:31 AM
Cheers - Jim
The AGMs are out, and the rest of the cabling in that area soon will be. The area may get used for a 15 gallon fresh water tank in the future as we took out the internal tank in the bolster a long time ago. All the hardware and bracketry is still there from the batteries so install will not be hard to do.
The original idea from a while ago was to hang the lithium underneath, but I had seen the battery temps we got with the AGMs there and changed our minds, when compared to the latest research on high temp damage to LiFePO4 batteries. Our AGMs would run 100-115* on hot days even when not on charge and that would not be good for the lithium. To keep them cool would have required a ventilation system into the van to get cooler air to them and I decided the interior space could be sacrificed without huge penalty and a water tank sounded really nice to do.
No heaters in ours as they are inside and we store indoors.
I did get the water tight plastic cases, but it doesn't really matter to us. The steel cased ones are taller and are said to interfere with the Bluetooth monitoring signal.
Our alternators could put out 300 amps or more easily, but the most we ever used on the AGM was 280 amps and that was in testing. I originally setup with a double limit on the amps, with one at 180 amps and one at 280, but found we never needed the 280 amp one. I changed them to 120 and 180 and we rarely even used the 180 amp either. The batteries are rated quite low for charge rate and I think it is related to the latest research on charge rates and also because they are 206amp cells so quite large in size. They show a recommended of 40 amps per 206ah battery with max of 70 so about .2C to .35C rate. This is in line with what I am reading about .2 being about where degradation increases. I think the old charging specs of 1-3C are going to go away with time as the manufacturers get too many early claims on the batteries. It has started already with quite a few say .4C recommended, which SOK does on the smaller cell 100ah cells. 120 amps will be the initial setup and probably be enough just like it was on the test trip and a lot trips with the AGM batteries, but I can always turn it up some if we need faster. If the solar is on, it will likely be even less of a question as we can get 100ah per day from that is good sun. We don't intend to idle to recover charge and will setup up the regulator to reduce output at idle, I think, as it appears to have that option. I never cared for big loads at idle in vehicles.
The Wakespeed would be able to drive both alternators to full output of 530 amps if we wanted to but the alternators will start to get hot at approaching the 280 amp region if run in hot weather. I have always preferred to oversize things and run lower to improve longevity and reliability. If the main concern was with rapid recover or idle changing, it would set up differently. The Wakespeed is claimed to maintain the amps and volts to the batteries by measuring off the shunt and then also produce enough power to cover loads for the rv stuff running and also run the van without compromising charge rate, so totally variable output. If true that will be a really, really nice feature to have.
I truly have no idea if the current "best practices" are correct or not, but in my engineer brain they make a lot more sense than the older ones. By adding one extra battery we are able to lower the charge rate per battery, lower the temp by moving them inside and charging slower, and have to drive less often so certainly looked from a winner except for extra cost and a bit of space in the van. We will also be less aggressive in charge voltage to prevent cathode plating and terminate charge based on charge amps to limit SOC to about 95%. All are within the latest claims of best and relatively easy to do so we gladly will be a test site to see if they really work well or not. In 5 years or so we will see what the "best" is then and know better, but by then we may all be using hydrogen fuel cells
10-10-2023, 09:04 AM
...but by then we may all be using hydrogen fuel cells
Then you could repurpose the extra water tank and use as a fresh byproduct tank...
Great summery of the setup. Thanks.
Cheers - Jim
10-11-2023, 01:10 AM
Now to what would probably be considered the more controversial part of this whole testing project, the charging control and settings. I am totally aware that what I intend to do is far from what a lot of the "drop in" style batteries list as recommended settings and I will attempt to explain why I think going to a different way is more suitable, at least for our system.
We have the ability to charge to any specific voltage limit and also have the charging terminated based on the amps to the batteries at the set voltage. This is the best way to charge AGM batteries to tail amps so we have it left over from the AGM system we just removed. As I read more and more scholarly papers on lifepo4 battery charging the premise of charging to an amperage level started coming up as preferred very regularly. Consistency of process was the most common reason to choose such a method as voltage changes are too small for that to be used accurately, while the amperage changes are quite large in the changeover zones.
The information I am mostly missing is coming up with what is really the best amperage to terminate charging at any particular voltage.
I decided to try to "back door" that decision by working backwards from what I consider other best practices for charging. I chose a 13.8v max charge voltage and a resting SOC after charging of 13.35v which is in the 95% SOC range.
Those parameters allowed me to conduct on the fly testing on our 30 day shakedown trip by charging at 13.8v until the amperage to the batteries dropped to various levels, and then terminating charging and letting the batteries rest a while to see what voltage they settled at. From those tests it looks like 50-60 amps at 13.8v will probably be a good point to be at, but still needs to confirmed with better controls and more data points.
Once I have these points, setting up to do it with our equipment gets much easier. I just set the solar and shore chargers to 13.8v absorption and the tail amps to 55 and good to go. I think the Wakespeed alternator regulator will be able to do the same but don't know that yet as I it hasn't arrived and been installed to this point.
As it is stated above I have chosen 13.8v max voltage and 95% max SOC for my limits on charging. I believe that these should be the best balance of charging speed and battery life, but we all know lithium best practices change with the wind so could be way off also.
Many batteries charge much higher to 14.6v to get to 100% full, but it appears this may cause life issues per much of the literature. Same is true about going to very deep discharges to near zero SOC. Those recommendations may just not have been updated or could be influenced by marketing and warranty issues, but I have no idea what is going on. They may also be the best, who knows at this point.
The gist I got from lots, and lots, of reading on the topic is that higher temps, maybe even over 95*F, shorten life. Higher voltage, maybe over 14.1v but certainly over 14.4v shorten life. Time spent at either of the above issues adds continuously more damage. Holding at moderate to high voltages when charge current is very low may be a problem but not as certain as the above two. Battery life gets shorter based on how deep the discharges are before charging, similar to what we know about AGM batteries, but maybe even worse. There are a lot of conflicting specs on this issue. lower charge rates in the .2-.4C are recommended for longer battery life as well as lower discharge rates than the 1C and greater previously stated.
So, bottom line is I chose what I chose based on what I felt the best information indicated would work best with our system. It may be right or wrong, but I bet at least I will learn something from it all and that was the purpose of this whole test install.
I hope others take other paths and share how it all works out so we have some comparison data.
I will also be very interested in how Avanti sets up his larger and more sophisticated bank on his new van, as I am sure he has been reading a lot of the same stuff I have.
10-11-2023, 07:16 AM
Charging termination based on the current set point at the final voltage level will require charging by one charging source only. Selection of one of the three sources, alternator, PV, or shore, would like to be done manually, not a big issue but attention would be required.
Do all of your charging sources have capability for current tail end termination at owner selected voltage?
10-11-2023, 11:59 AM
We have done charging from multiple sources to tail amps at the same time for many years as they seem to play together just fine.
It was always two sources though, as there isn't really a case where we would have all the sources running at the same time. It was solar/shore or solar/alternator.
Both the solar and the shore charger will automatically and independently charge to the reading of amps from the same shunt. Minor differences make them shut off at slightly different times, but close together if set to be that way.
The alternator charging was done manually as I drove by watching an ammeter on the dash and shutting off the charging when it was done or the solar could produce enough to finish the charge automatically.
Hopefully, the Wakespeed will make the alternator charging also automatic so I don't have to worry about watching it. The lithium amps change very rapidly at the desired end point so if you are in traffic or other attention needing conditions it is easy to miss manually so automatic will be very nice to have if it works.
The solar and shore chargers are fully settable for voltages, tail amps, and/or hold times. The current regulator is the weak spot with only preset voltages, IIRC about 4 options, and the current is set via putting a cap on field % and only limits charge rate. Alternator charging now is not automatic but should be in the future with full amps/volts ect setability.
