Old 09-13-2023, 03:23 AM   #1
Default 2016 airstream interstate shade motor
Good evening, I posted this question recently but with no avail.
I ordered a shade motor from Amazon to avoid the 300 plus OEM replacement. Motor fit and works but does not function with the shade remote.
Do I need to program the new motor?
Has anyone encountered the same issue with Amazon shade motors?
Thank you all for your help!
Johnny16EXT is offline   Reply With Quote
Old 09-22-2023, 02:19 AM   #2
Boxster1971's Avatar
Attached clip from the owner's manual indicates you must reprogram the remote when replacing the motor. It also makes reference to reprogramming instructions in the power shade owner's manual.
Good luck,
- - Mike
2024 Airstream Interstate 19
Old 09-25-2023, 03:34 PM   #3
Thank you for your reply, would you happen to know where I may obtain the Power shade manual?
Old 09-26-2023, 01:23 AM   #4
One would have been provided by Airstream with the van when new. But if you are not the original owner you probably don't have it.
You could call or contact Airstream Customer Service to get a copy.
If you have the brand name you could search for a copy of the manual online.
I believe in 2016 Airstream used AutoMotionShade products.
Try looking at this web site for help:
Auto-Motion Shade | Support | SUPPORT
Good Luck,
- - Mike
motor, programming, shades
