Old 11-08-2016, 04:27 PM   #1
Default How To Get a Wire Inside the Coach
Can someone tell me how they ran a wire from outside their rig into the interior? Specifically, what I am wanting to do is connect a battery monitor wire from the battery (outside) to a monitor on an interior wall. This is on a 2004 RoadTrek 190 Popular on the Chevy Express 3500 chassis. I would like to avoid drilling a hole. I looked underneath yesterday and didn't really see where I could run the connecting wire through to the interior. Any info would be much appreciated.
Old 11-08-2016, 04:38 PM   #2
The previous owner of my van ran a wire for a backup camera alongside the wires for the taillights in the back. If you have the dual battery setup like my 2003 190 does, the rear battery is close to the back doors.
If that doesn't work for you, then my next thought is to run it alongside the battery cable & bring it in the van where that cable comes in.
2003 Roadtrek 190 Popular
Gryphon is offline   Reply With Quote
Old 11-08-2016, 05:49 PM   #3
I hadn't thought about the taillights route - thanks!
Old 11-08-2016, 07:19 PM   #4
wincrasher's Avatar
1/2" drill bit. Carbide tip, titanium bit.
2019 Winnebago Travato GL
Old 11-08-2016, 09:45 PM   #5
No No, a 12 Gage shotgun slug is simpler and 1/2 inch!
Old 11-09-2016, 02:51 AM   #6
Bruceper's Avatar
Always this.
Old 11-28-2016, 10:05 PM   #7
I did this on my 210P. It takes a bit of ingenuity to pull it off. I installed my battery monitor on the AC/DC plastic panel (along with an AC monitor) I fished the wire down to the hole for the outside light switch from there, down to the side door post (drilled 3/8 in hole), from there back (using a fish tape) from there along the frame rail to the battery drawer. It took me several sessions of experimentation and poking to get the wire installed. I installed the shunt inside a 6 inch length of 2 inch CPVC sewer with caps on each end and ran a #2 cable to the negative battery terminal. The sewer pipe protects the shunt and connections from acid fumes and shorting. I tie wrapped the assembly to the rear of the battery drawer.
Old 11-29-2016, 05:48 PM   #8
Hmm... now you got me thinking... I kinda like the way you did this. Thanks!
Old 12-02-2016, 09:33 PM   #9
I did it by running the wire inside the body structure holding the passenger side rear door hinges. You do have to remove the interior panel that holds the thermostat and a few screws on the one that runs across the back. With that you can get the wire to the thermostat area.
From there you can get to the aft facing panel on the passenger side to mount your monitor.
Harry 2003 C190P
Old 12-02-2016, 09:59 PM   #10
Harry 2003 C190P
So you connected the front or the rear battery...? And from the battery into the coach you went... how? Sorry but I'm not seeing this. Thanks.
Old 12-02-2016, 10:29 PM   #11
Rear battry...up the inside of the door post.
Old 12-02-2016, 10:31 PM   #12
Default How To Get a Wire Inside The Coach
I had an '05 190P, and installed a macerator. To have the electric, I ran a wire thru the long side compartment, over and punched it thru a seal/boot that had wires going to the operations under the passenger side bed. I then hooked it up to a vacant slot. Don't know if this helps. Ron
Ron J. Moore
'15 RT210P
Old 12-03-2016, 03:05 PM   #13
yes that does indeed help - thanks sooo much!
