Old 05-10-2023, 01:02 AM   #1
Default 2006 Roadtrek 210 stove top cover
I want to install a stove top cover in my roadtrek. I have the top but it doesn't have any installation hardware or instructions. Has anyone done this? Some pictures of one and how it is attached would be extremely helpful. Thanks
ph007 is offline   Reply With Quote
Old 05-10-2023, 04:53 AM   #2
I don't have a roadtrek, the internets shows me this 2006 210 popular which has a couple pictures of the galley and a lift off cover.
here:
https://www.rvusa.com/2006-roadtrek-...lass-b-3492117
Old 05-10-2023, 04:20 PM   #3
... I don't know if RT provides a space to stow the cover or a 2nd use for it ( pleasure way uses their cover to extend the counter space- very handy)
Old 05-11-2023, 02:49 AM   #4
Interesting. Do you have a pic to share of how the cover works as an extension?
thx.glenn
Old 05-12-2023, 06:48 PM   #5
I have a devil of a time posting pics here... so a B option below
on the side of the cabinet ( facing the back of the pass seat) Is a support which pulls out ( blocking the side door access) the cover sits on that.
in this video at 3:51, the piece of wood trim below the cover and above the light switches pulls straight out- it is on rails and these are the supports for the cover:
Old 05-12-2023, 07:03 PM   #6
Thanks Mike. I see how it works. Unfortunately on my 97 the sink and stove are reversed (sink closest to side door access). The stove side butts right up against a full wall. I would like to have some counter extension but I'll have to think of another way of doing it.
Glenn
Old 05-13-2023, 02:14 PM   #7
In my last RV I used another person's tip. I bought a plastic chopping board and cut it to size. MUCH lighter the the original, plus you could use it to as a cutting board.
2005 Roadtrek 05C210v
2020 Can Am Spyder RT Limited
Bangorbob is offline   Reply With Quote
Old 05-15-2023, 10:22 AM   #8
The previous owners of our RT made a stove cover out of a wooden cutting board with some side pieces of wood glued/fitted below such that the assembly fits over the stove perfectly and doesn't slide around.
When we're not using the stove, we get a huge increase in counter space. Brilliant!
When we do use the stove, we typically use the cover/cutting board for chopping or serving or both. So no compelling need for storage.
The other cool/unique thing they did was to paint all the wood white. Really brightens things up, tho also shows dirt/wear a bit more than the OG wood finish.
If interested I can post some pics & dimensions tmrw.
Best,
Scott
99D190P
scottdailey is offline   Reply With Quote
Old 05-15-2023, 12:29 PM   #9
Yes, please post some pictures.
thanks
Old 05-16-2023, 02:56 AM   #10
Have you thought of perhaps using a correctly sized baking pan (say 12x17) that was deep enough (2-3"?) so that it could be flipped over on the burner grids. Perhaps with a wooden or plastic cutting board screwed on from the bottom of the pan into the wood.
Old 05-16-2023, 05:27 AM   #11
the cover on my PW is wood, with a formica top which matches the counter.
the underside has sheet metal for protection. I always test with my hand before putting the cover on but... you never know how stupid we can be.
there are also 2 clips kinda like as shown below- the female part is recessed into the edge of the counter. these keep it from rattling
