Old 01-11-2011, 09:29 PM   #1
Default huge enclosure box for a water pump? is it necessary?
The small water pump on the RT Agile is enclosed in a huge box about 18 x 18 inch big, reading from the shureflow water pump manual also mentions installing the pump in a spacious compartment. Why? I dont get the rationale behind this. Thanks.
inutel is offline   Reply With Quote
Old 01-11-2011, 11:13 PM   #2
Mike's Avatar
Default Re: huge enclosure box for a water pump? is it necessary?
Try sending your question/comment to
service@roadtrek.com
They should be able to explain it.
Don't forget to include your make/model and VIN number.
If you aren't yet registered with them (i.e you're not the original owner),
that's another good idea to assist them to respond when you have questions.
Old 01-11-2011, 11:21 PM   #3
Accessibility is my guess, to change the filter etc. You need room to work.
It'll be interesting to hear what Roadtrek says.
Old 01-11-2011, 11:24 PM   #4
Mike's Avatar
Probably, as it's difficult to get at mine to change/clean the filter or to try to
get it out to replace or repair. Wish I had more room.
btw, did you find an old box in the garage, full of class b videos?
Old 01-12-2011, 12:43 AM   #5
I finally got high-speed internet last week and have been rediscovering streaming video etc.
Old 01-12-2011, 12:49 AM   #6
Mike's Avatar
I never would have guessed!
Old 01-12-2011, 01:05 AM   #7
Thanks, ill email them and see what they say.
Old 01-12-2011, 01:37 AM   #8
Mike's Avatar
No problem. When it can't be googled or searched on here specifically, Roadtrek Service is
usually the next place I ask, for all things Roadtrek. I once had a question about adding a
roof mounted satellite dish system, and they sent me pictures of my '02 roof in various stages
of assembly, showing where the existing wiring was located, so I could cut and drill without
doing damage. They will also give insightful answers on "why" type questions if they know
the "because" answer.
(after looking at the pics, I decided on another way to get satellite TV. no cutting involved )
