Old 06-18-2021, 10:56 PM   #1
Default Fan noise in rt 190
Newby here. Noticed a fan sound coming from the area of the pump and Heater. Stays on when pump is off. Any idea what this is? Wouldn't a nonstop fan kill the house battery?
alwechs is offline   Reply With Quote
Old 06-18-2021, 11:18 PM   #2
not familiar with your model
do you have an inverter ?
Old 06-19-2021, 03:12 AM   #3
More information on your precise year and floor plan might help, but the short answer is you are correct to worry it will drain your battery.
I'd probably start pulling fuses to stop it until you can diagnose the problem further.
Old 06-19-2021, 04:11 PM   #4
alwechs, were you plugged in when you noticed the noise? If so, it may simply be the cooling fan on the charger. Unplug the shore power and see if it goes away. Be sure your house power is turned on like you would be if you were not plugged in and relying on your coach batteries.
Old 06-24-2021, 05:10 PM   #5
Could it be the fan in the Range Hood?
Panman is offline   Reply With Quote
