Old 01-11-2021, 07:19 PM   #1
Default Rear Windshield Wipers
I have a 2018 Dodge Promaster Roadtrek Simplicity. It did not come with rear windshield wipers and I would now like to get them installed. I contacted Roadtrek and they responded with "We do not have access to any kit that would put rear wipers on the vehicle."
Does anyone have a recommendation on whether this is possible? It seems crazy to not be able to install.
Alisa Bondurant is offline   Reply With Quote
Old 01-11-2021, 10:26 PM   #2
Dodge does not make the Promaster. Try your local Ram Truck dealer.
2008 Roadtrek 210V
Formerly:
Toyota Sunrader
Tiffin Allegro
Foretravel U225
wny-pat is offline   Reply With Quote
Old 01-12-2021, 12:54 AM   #3
I've never seen that option so not sure it exists.
Old 01-12-2021, 02:24 AM   #4
I have rear windows wipers ordered from the factory. It was a few hundred $ option so adding them could be rather expensive if realistically possible.
If you want to increase visibility through the rear windows, I found Fresnel lenses very useful. I like them a lot.
Old 01-12-2021, 11:53 AM   #5
Jon in AZ's Avatar
All of our last 6 or 7 daily-driver vehicles have had rear wipers (we gravitate toward station wagon/minivan/SUV body styles). I personally find them more trouble than they’re worth: easily damaged, trap dirt and leaves, prevent snow from sliding off, often smear rather than clear, hard/expensive to replace blades on some, and limited field of view. One became such a nuisance I paid to have it removed. I certainly would not pay good money to add one (and twice to add two on split cargo doors). They really need a washer to be much use.
If you do decide to proceed I agree a Ram Promaster dealer is the place to start. They can tell you if it was offered as an option and whether it's possible to retrofit. I also did a quick search on "universal rear window wipers" and found some parts- motors and arms- you might cobble together and build your own if you're so inclined. Anything non-factory will detract from resale value.
I had one of those lenses on a previous van I owned, and I agree they work well, though they will become dirty along with the window and the rest of the back of the van. They address a different problem.
A rear camera that can be activated when moving forward is another option. Yes, it will get dirty, too, but it’s fairly small and quick to clean at each gas/rest stop. A high-mount camera (over the cargo doors) will accumulate less road spray.
For myself, I am best friends with my side mirrors. If an 18-wheeler can navigate safely with only side mirrors, surely I can too.
2014 Roadtrek 190 Popular
2008 Scamp 13
Jon in AZ is offline   Reply With Quote
Old 01-17-2021, 03:53 PM   #6
I have had good luck with rainx , follow directions and clean window beforehand!
jjustj is offline   Reply With Quote
Old 01-17-2021, 07:02 PM   #7
Anythings possible if you want to throw the $ at it. I did add a rear wiper to a hatch back car I had years ago. Bought wiper motor from another car at the auto wreckers and installed. It worked well but I have had rear wipers and washers on many cars/truck now and generally as someone else said they tend to smear the window dirt around without a washer. It’s not something I would add. Our old VW Westfalia had it from factory and we actually never used it - not once, the window stayed pretty clean between fill ups when I would clean the rear window and taillights along with the windscreen.
Ken
_____________________________________________
2021 Ford Transit AWD ‘Iron Horse’
Formerly - 2007 Pleasure Way Plateau (06 Sprinter T1N), 1992 VW Eurovan Westfalia Hightop
Long ago - 1969 VW Westfalia & 1973 GMC Motorhome
ks@yvr is offline   Reply With Quote
Old 01-17-2021, 07:14 PM   #8
LOL....I'm always amazed at the mods people want to do...maybe hire a little person to wipe the back windows
windshield wipers
