Old 07-24-2020, 02:34 AM   #1
engnrsrule's Avatar
Default Water in Fuel Filter Warning Light
I recently changed my diesel fuel filter on my Roadtrek Sprinter. Since then I have gotten the water in fuel filter warning light a few times. I have had the RV 2 years and never got this light before.
I follow the process to purge the water - Locate the purge hose on top of the filter assembly; Direct the hose into a container; Open the purge valve; Briefly turn on the ignition to turn the engine over. Close Purge Valve & restore purge hose.
After this process the light clears, but comes back a day or so later. Tank is 3/4 full and this has occured between trips. I do not want to be dealing with this on the road.
Has anyone experienced similar issues?
Old 07-24-2020, 11:27 AM   #2
Sounds like you have water in your fuel tank and the filter is doing its job. Probably you got a bad batch of fuel somewhere.
I have no experience with this, but I gather from postings over at Sprinter-Source that this is not a Good Thing and can lead to very expensive repairs if ignored. I suggest you (a) go over there and do a search. IIRC, there is a Sticky thread on this topic; and/or (b) take a trip to your dealer or someone else qualified to drain and purge your fuel tank.
Again: my understanding is that this is not a trivial matter. The high-pressure fuel injection system is both fussy and expensive. That fancy filter system is there for a reason.
Old 08-25-2020, 12:07 AM   #3
engnrsrule's Avatar
Default Solution to water in Fuel
Update to the problem... after several recurrences of doing the strip process for water in the fuel filter, I asked my diesel mechanic and he recommended Power Service Diesel Fuel Supplement & Cetane Boost. It is carried at Autozone.
Recently took a 900 mile trip and problem has not recurred.
I will add that I usually get fuel at Shell, but the last trip before this problem showed up I had used a Pilot Station.
Old 11-23-2020, 02:40 AM   #4
engnrsrule's Avatar
Update...not sure what is going on with this, but I note that the water in fuel filter light comes on at every start up. I have gone thru the purge process and it goes away, but in examining the purged fuel there is no trace of water. I also found that if I turn the key to start, then off, then back on to start the light goes out. Ideas welcome...
Old 11-24-2020, 03:17 AM   #5
Boxster1971's Avatar
I'd just change the filter again. Did you use an original quality filter when you changed it before the problem started?
2024 Airstream Interstate 19
Old 11-24-2020, 12:14 PM   #6
engnrsrule's Avatar
Thanks Boxster, I will give that a try. This is what I used...
https://www.amazon.com/dp/B00I8J1KZY...ing=UTF8&psc=1
Old 11-25-2020, 03:03 AM   #7
That is a cheap Chinese made fuel filter. Ecogard is a brand subsidiary of IPC Global Solutions that manufacturers most, if not all, their parts in China.
https://ipcglobalsolutions.com/about-ipc/our-company/
Mercedes vehicles just don't do well with lower quality parts. The Sprinter-Forum is full of stories about poor quality filters. Get and OEM filter from a dealer or try some of the online parts seller that sell OEM filters. I pay $120 for a OEM fuel filter from a Freightliner dealer for my 2012 Sprinter. But fuel filters for your Sprinter are cheaper.
You can likely get a fuel filter for your older Sprinter for $50-60 from NAPA. Apparently they sell the same OEM filter used by Mercedes at a much lower cost.
I assume your Sprinter is branded as a Dodge, or is it Freightliner? You might even be able to get a reasonably cost filter from a Dodge or Freightliner dealer.
Good luck.
- - Mike
